Slash's "Budget" Built Trail Limo and BS, Now with Polls!
Discussion in '2nd Gen. Builds (2005-2015)' started by Slashaar, Mar 2, 2018.
Should I buy a 1st gen FRS/BRZ/86?
  1. Yes
    1 vote(s)
    11.1%
  2. Hell Yes
    4 vote(s)
    44.4%
  3. No, get another boring corolla!
    4 vote(s)
    44.4%
  1. Nov 24, 2020 at 4:19 PM
    #841
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Was there a bigger discount for x3?
    MarX likes this.
  2. Nov 24, 2020 at 4:36 PM
    #842
    Slashaar
    Slashaar [OP] Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Nope, just says 15% for 2+ products. Idk what they could get us through the FB group.
    mcharfauros and MarX like this.
  3. Nov 26, 2020 at 10:21 AM
    #843
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Happy thanksgiving.
  4. Nov 29, 2020 at 2:17 PM
    #844
    Slashaar
    Josh
    Kansas City, MO
    The financial department and I did some numbers and the discount isn't enough for us to be scrambling for the items so we've decided to put it off for now.
    Bigdaddy4760, MarX and mcharfauros like this.
  5. Nov 29, 2020 at 2:56 PM
    #845
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    There's no dislike button...
  6. Nov 30, 2020 at 2:32 PM
    #846
    Slashaar
    Josh
    Kansas City, MO
    Same. I kinda talked it us down off the ledge. We're looking hard at the suspension and thinking it'd be better to prep for the weight after everything goes on. So @81Trekker 's JDFabrication Bolt-on 62" Swap, 14" Travel Shocks purchased from you know who ;), and heavier coils in the front.
    Time now is to think what spring rate I need. I assume 700lb but I'd like to hear your thoughts. Once I have skids, sliders and the dual swing rear on its gonna be a heavy pig. Also need to consider what 62" leaf pack I'll need. We've also been talking regear to 4.88.
    MarX and Sasquatch3153 like this.
  7. Nov 30, 2020 at 3:51 PM
    #847
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    Yes :anonymous:
    MarX and Slashaar[QUOTED][OP] like this.
  8. Jan 6, 2021 at 4:53 PM
    #848
    Slashaar
    Josh
    Kansas City, MO
    Damn I haven't posted in a while in here.
    Priced out all the bits and bobs for the 63 swap and it's coming in around $800~ (before shocks and relocation so ~$1400 optimistically) which is a lot less than what the JD fab kit would cost me. I know his stuff is super top notch, and it would be super easy to just bolt on the kit, but this is a budget build. Plus I get to weld on my truck some more, so 'Built not Bought'?
    Saved for reference: https://www.tacomaworld.com/threads/how-to-chevy-63-leaf-spring-swap.377756/
    Anyways I'm also planning the sliders. I really need to get on top of getting them done. That 8' of 1/4" wall Square tube isn't gonna cut itself. Priority one is measuring how long I want the runners to be so I can see how I'll go about cutting them since there will be 8 runners, 4 on each side for maximum strength (as if 1/4" wall tube wasn't enough). Since the main part is already done I just need to set one side on jack stands and position it where I want it. After that I can measure the distance and get my numbers. I'll cut it on the plus side just in case.
    Then I remembered that @1 Bored Clerk graciously provided us with the cad files for bolt on plates: https://www.tacomaworld.com/threads/diy-bolt-on-frame-plates-for-sliders.302192/
    So that's in the realm of possibilities and makes me feel a lot better not having to weld these suckers to the frame. We'll see.
    Time to start stacking pennies....
    Once suspension is all sorted (which reminds me I need 700 lb coils, add that to the list) we are moving on to stage 2 with Regearing, full skids and rear high clearance.
  9. Jan 6, 2021 at 4:57 PM
    #849
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    :popcorn:
  10. Jan 7, 2021 at 8:51 AM
    #850
    ResearchMonkee
    Derrick
    KCMO
    Wanna measure my runners?
    Thanks for 63 spring link, lol.
  11. Jan 7, 2021 at 3:37 PM
    #851
    Slashaar
    Josh
    Kansas City, MO
    I'm deciding on whether I'll stick them out a bit longer than the usual or not. Wouldn't be much more than an 1" difference though. The 1/4" wall tube is going to be way overkill so I have no problem worrying about hits there.
    MarX and ResearchMonkee[QUOTED] like this.
  12. Jan 7, 2021 at 3:55 PM
    #852
    ResearchMonkee
    Derrick
    KCMO
    These are mine for reference at least.
  13. Jan 18, 2021 at 7:19 PM
    #853
    Slashaar
    Josh
    Kansas City, MO
    MarX, Bigdaddy4760 and Sasquatch3153 like this.
  14. Jan 18, 2021 at 7:32 PM
    #854
    Bigdaddy4760
    Maner
    Poolville Texas
    MarX likes this.
  15. Jan 18, 2021 at 8:29 PM
    #855
    Slashaar
    Josh
    Kansas City, MO
    BR6s in Stealth blue..... :drool::drool::drool:
  16. Jan 18, 2021 at 8:41 PM
    #856
    Bigdaddy4760
    Maner
    Poolville Texas
    Badazz
  17. Jan 19, 2021 at 1:39 PM
    #857
    Slashaar
    Josh
    Kansas City, MO
    Gonna be awhile. Hopefully get the 63s under the rear first and skids and sliders on. Then I'll regear and move toward 285s instead of skinnies which will mean needing the negative offset wheels.
    The OEM Sport rims have a +30 offset which means even with my spacers the tire sits very close to the UCA/Coil at droop.
  18. Feb 10, 2021 at 11:59 AM
    #858
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    Do you have you BOM for the swap in an Excel file or anything? I'm starting the exact same thing and I like when I can just ask somebody I trust for what they did that worked. If you don't have that, maybe it would be worth me putting one together with part numbers?
  19. Feb 10, 2021 at 7:29 PM
    #859
    Slashaar
    Josh
    Kansas City, MO
    So ruffstuff parts (Ideal 63 swap kit and outriggers) are around $350. Leafs are $152 a piece new from KC Springs. Then Braided extended length brake lines will be in the realm of $150. Finally the straps will be like $60 IIRC. Then I'm buying 14" (IIRC?) shocks from @Sociopenguin
    Oh and the shock relocates will be JD Fab since they can take a 14" travel shock and using geometry? Trigonometry? Math. to make it 19" of flex at the wheel. I need to call the shop to find pricing on that though. I tried pming @81Trekker but I'm sure he's super busy. I just haven't remembered to do it until after the shops already closed. :facepalm: Working nights sucks for that kind of thing.
    The other route I could go is full JD Fab but it's a little more pricey which is not budget built. The flip side though is his 62" swap setup is full bolt on. So you should check that out if you want the easy route.
    DIY for the 63 is gonna take a lot of beer, time and patience. Maybe a couple stogies too.
  20. Feb 10, 2021 at 7:31 PM
    #860
    Slashaar
    Josh
    Kansas City, MO
    Honestly, I think taking the bed off to do it, would probably make it the easiest. @ovrlndkull did so at @Casper66 's house and it seemed like it made getting everything right easier. IIRC.
    MarX, Juisebocks, Casper66 and 2 others like this.
