Slash's "Budget" Built Trail Limo and BS, Now with Polls!
Discussion in '2nd Gen. Builds (2005-2015)' started by Slashaar, Mar 2, 2018.
Should I buy a 1st gen FRS/BRZ/86?
  1. Yes
    2 vote(s)
    20.0%
  2. Hell Yes
    4 vote(s)
    40.0%
  3. No, get another boring corolla!
    4 vote(s)
    40.0%
  1. Sep 27, 2022 at 9:00 AM
    #1381
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Every three years is the standard.
  2. Sep 27, 2022 at 9:20 AM
    #1382
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    I need to get around to some maintenance but I've been super lazy. Diffs are due, vatozone cv boots are cracked, greasing upper and lower bushings and more. With going out more I need to make a maintenance schedule and stick to it.
    MarX and Slashaar[QUOTED][OP] like this.
  3. Sep 27, 2022 at 9:28 AM
    #1383
    Slashaar
    Slashaar [OP] Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Just do it! I try to stay close to the factory maintenance manual. 30k on diffs and transfer case and grease all fittings. According to it they are also supposed to check your tappet noise levels, but since I'm DIYing I have no clue on that aspect.
    Engine oil I do at 10k intervals with Mobil 1 full synthetic 5W-30 Extended Performance. Rated for 20k intervals so I feel confident at 10k. OEM filter.
    Oh yeah, forgot to mention that, I also greased every zerk I could get my grease gun on. One of my greasable LBJs the fitting is clocked too close to the spindle so I couldn't get the gun on it.... :pout:
    Oh well if the LBJ starts to go, it's got a lifetime warranty on it. I'll just get a new one fo free.
    MarX and HIYota[QUOTED] like this.
  4. Sep 29, 2022 at 11:24 PM
    #1384
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Does anyone really follow that lol
  5. Sep 30, 2022 at 5:31 AM
    #1385
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Probably not really but because of the hygroscopic nature of brake fluid they recommend it.
    Not that a brake fluid change is ever done totally either so there is that too.
    MarX[QUOTED] and Slashaar[OP] like this.
  6. Sep 30, 2022 at 5:45 AM
    #1386
    Slashaar
    Josh
    Kansas City, MO
    I just need one of those sweet speed bleeders and techstream so I can cycle the ABS too.
    MarX, HIYota and Sociopenguin[QUOTED] like this.
  7. Sep 30, 2022 at 9:03 PM
    #1387
    MarX
    Mark
    NE Kansas
    Are those pricey?
    Slashaar[QUOTED][OP] likes this.
  8. Oct 3, 2022 at 5:40 AM
    #1388
    Slashaar
    Josh
    Kansas City, MO
    Techstream is the Toyota software that the dealer uses to do all sorts of other things. For this it allows you to cycle the ABS pump without slamming on the brakes on the highway so you can bleed any air in the system.
    Techstream isn't cheap right out, but there are things you can do to get around that, like buying a Toyota knock off OBD to USB adapter online and then getting the software through someone. I'm sure @CygnusX191 could explain more features of it since he now gets to use it at work.
    A just allows you to bleed more easily. Pulls vacuum on the bleeder port and typically comes with a reservoir you can attach to the factory reservoir to increase the capacity while your cycling fluids so you don't run the system out and put yourself in a perpetual cycle of frustration.
    MarX[QUOTED] likes this.
  9. Oct 4, 2022 at 6:01 PM
    #1389
    MarX
    Mark
    NE Kansas
    That’s crazy
    Slashaar[OP] likes this.
  10. Nov 24, 2022 at 6:24 AM
    #1390
    MarX
    Mark
    NE Kansas
    Happy Thanksgiving!
  11. Jan 4, 2023 at 4:15 PM
    #1391
    Slashaar
    Josh
    Kansas City, MO
    Noticed my road vibes were heavier on my way home today. Pulled up to the garage and got under with the inkling of carrier bearing. Sure enough 1/8" of slop in the sucker. My wallet is now $144 lighter since I might as well also replace all 3 U joints. Ordered through Summit since they had the lowest prices. Yay. Now to decide if I buy a 3 jaw puller or just borrow one from O'Reilly's?
    MarX likes this.
  12. Jan 4, 2023 at 4:41 PM
    #1392
    MarX
    Mark
    NE Kansas
    I’d rent it
  13. Jan 4, 2023 at 7:18 PM
    #1393
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    I have a few. What size do you need?
  14. Jan 5, 2023 at 6:01 AM
    #1394
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Well....if his parts show up......
    Sasquatch3153 and Slashaar[OP] like this.
  15. Jan 5, 2023 at 10:30 AM
    #1395
    Slashaar
    Josh
    Kansas City, MO
    Whatever size the carrier bearing is. I have the write up bookmarked on my home pc. I'll let you know. Might just be faster to 'rent' it because I believe you get your money back on return. Though I've slept many times since the last time I borrowed one and my memory is fuzzy.
    MarX, Sasquatch3153 and Sociopenguin like this.
  16. Jan 5, 2023 at 10:35 AM
    #1396
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    That is the way rental tools work. But inspect it on site before you leave as they are many times junk.
  17. Jan 5, 2023 at 7:16 PM
    #1397
    Slashaar
    Josh
    Kansas City, MO
    Well this happened on my way home after work. Some people man. IDK what this guys deal was, but after he locked it up his wife/gf let him have an earful. For whatever reason my cam didn't pick up audio but I yelled at him over the PA "GET THE F OFF THE ROAD YOU DUMB F"
    MarX and Sasquatch3153 like this.
  18. Jan 5, 2023 at 7:31 PM
    #1398
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    Freaking idiot
    Slashaar[QUOTED][OP] and MarX like this.
  19. Jan 6, 2023 at 5:37 AM
    #1399
    Slashaar
    Josh
    Kansas City, MO
    Well according to Summit they show up today! Glad I didn't shell out for "expedited 2 day" shipping!
    Sear87 likes this.
  20. Jan 17, 2023 at 6:55 AM
    #1400
    Slashaar
    Josh
    Kansas City, MO
    Driveshaft rebuilt and back in the truck after waiting around forever for replacement parts as I broke 2 ujoints during assembly. Stupid Needle bearings.... :annoyed:
    MarX, Sear87 and Sociopenguin like this.
