Sleeping in truck bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3rdgntaco, Apr 14, 2020.
  1. Nov 14, 2023 at 9:41 AM
    #81
    BamBeds
    BamBeds Founder/Designer Vendor
    Ben
    Central Coast, CA
    '09 Access Cab TRD OR
    Bilstien 8100, 8112, Snugtop w/ windoors
    Our boards do have some sag if you're putting two people one a single board (about an inch or so with 300lbs on a single board) but it's still well within the elastic range of the material.
    When you have two people laying on a 4" mattress there's almost no sag.
    If you're really concerned about sag for some reason you could grab a 2x10" from home depot and cut it to fit as a center support.
    I guarantee the strength of the boards so people don't have to worry about breaking anything.
    If you break it - you get a new one on me, including shipping.
    Hugh Jashole and 71tattooguy like this.
  2. Nov 14, 2023 at 10:42 AM
    #82
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    Did you go to the same DMV location both times and what was the reason they denied your request?
    I know another guy on here who has a cab high and was able to change the body type to PM. However, he was denied at the first location he tried, but he was successful at a different location.
  3. Nov 14, 2023 at 11:25 AM
    #83
    cactushead
    San Diego
    Due to the weight of 3/4” plywood, I made a full-sized platform (not BamBed) for my short bed using 1/2” Baltic Birch. I supported it with a couple of rectangular metal tubes that were available to me; a 1” x 1.5” steel tube and a 1” x 2” x 1/8” aluminum tube.
    Using metal cross members should be more than sufficient to support most loads. However, to ensure there wasn’t any flexing, I cut two pieces of 4x4 to fit under the platform. It was always easy to find a couple of small spaces between the camping gear, if additional support was needed for the platform. Whether driving or parked, the weight of gear/people on top of the platform kept the 4x4’s from moving.
  4. Nov 14, 2023 at 3:10 PM
    #84
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    :thumbsup:
    Great ideas here...
    So far, we have tended to use a ground tent when camping. But I've considered sleeping in the bed for some solo trips. The platform would work well to allow for storage. Thinking out loud, maybe 1/2 a platform might do the trick while traveling solo with the rear seat area providing additional interior storage space...
  5. Nov 15, 2023 at 7:24 AM
    #85
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    It’s been several years but one try was at an actual DMV and the other was a AAA DMV. They said it didn’t qualify as “liveable” and that it wasn’t permanently mounted.
  6. Dec 17, 2023 at 9:08 PM
    #86
    tgoff
    tgoff Active Member
    2019 Tacoma TRD Access Cab Manual Transmission. OVRLND Camper.
    Yes, it works well for my purposes. Very easy to remove and allows adequate storage under the platform with the dog bed on top. I have some ideas to try for a lighter weight version of the box for under the platform.
  7. Dec 17, 2023 at 9:46 PM
    #87
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    I slept in the bed of my 02 Tacoma with the 6' bed and my 06 Tacoma 5' bed for something like 15+ years. Just threw in a pad. Then I got old! Too hard to get up and pee in the middle of the night.
    With the 5' bed I left the shell window open and draped a tarp over the open end. Froze my butt off a couple of times. Bought a Winnebago Minnie Winnie to camp in and now I pee in style at night!
