Sleeping in your Truck?? Winter Time??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gundamzero, Dec 29, 2020.
  1. Dec 29, 2020 at 12:35 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I am a big guy and have slept in my truck many times. Don't know why you don't want to run it but if you don't you need the smallest coldest rated sleeping bag you can find. Wear a toboggan too.
    I was trapped in my truck for 22 hours once in a blizzard. I was in my 2013 4Runner with 4.0 V6. I didn't sleep much and let it idle the entire time to stay warm. I cracked my driver's side window and got out and made sure my tail pipe was uncovered every few hours. Bottom line I learned that an idling truck will burn a quarter to a third of a gallon of fuel an hour. I had just filled up and once I got moving again I went to the next gas station and put in 7.5 gallons. So for a six hour idle you will use around two gallons of fuel.
    WELLSPRING, Evdunn, Junkhead and 7 others like this.
  2. Dec 29, 2020 at 12:37 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    sleeping diagonally in a capped short bed is good im 5'11" 200lbs. Small blow up mattress to fill the space and a sleeping bag. Its all about what you have to do to make it work.
    Its amazing what you will endure when you know thats its not permanent
    Koolbreeze7 likes this.
  3. Dec 29, 2020 at 12:42 PM
    trajiiic
    trajiiic Well-Known Member
    Hell yeah, brother! Didn't know the Navy got down like that.
  4. Dec 29, 2020 at 12:43 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    We have our moments :oldglory:
    trajiiic[QUOTED], Mark77 and hiPSI like this.
  5. Dec 29, 2020 at 12:46 PM
    Spunky
    Spunky Well-Known Member
    Dean
    Minnesota
    2015 blue
    None yet
    Small futon in the bed worked for me in college. May find a used one cheap.
  6. Dec 29, 2020 at 1:01 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Never slept inside the truck myself, so I cant really give any advice on that as far as how to or what not. But do have enough cold weather camping experience that Ill add a few notes.
    As others have said, grab a very good sleeping bag. Rated to as low as you can reasonably afford. -30*C is probably a good start given you are going to be inside the truck and therefore sheltered from the direct elements. Beyond that, a hat and good dry wool socks and base layer pants/ shirt will all help.
    One thing you will undoubtedly have problems with is condensation inside the truck. The human body emits a metric F ton of humidity. This will make every surface wet, and if its -30*C that will soon freeze. I would highly recommended getting some side window visors. Then you can crack all 4 windows without letting a ton of snow in (even 5 if you want to crack the rear window) to allow for max circulation of fresh air. Waking up in the middle of the night to condensation dripping on you and coating the outside of your sleeping bag is no benuo.
    On the same note, give yourself plenty of time in the morning to warm the truck and run the defroster to clear the windows clear before you have to drive away. Hard to say how long that could take.
    Unfortunately Buddy heaters also produce water vapor as a result of the combustion reaction. So Im not sure I would recommend one of those.
    If this a long term gig (all winter) you may look into one of those cheap diesel heaters. You could set it up in the bed, plumb the hot air duct into the back window. That would make a huge difference to keep the humidity low, and also help with temps. Up to you if you think the setup / takedown time and hassle is worth the tradeoff
  7. Dec 29, 2020 at 1:06 PM
    Ronbo1
    Ronbo1 Well-Known Member
    Ron
    2020 Tacoma SR
    Topper, 3" front lift, Duratrac 265/70 r16's
    I've seen others here post about 12v blankets. Don't know much about them but I'd imagine you'd need/want a second battery
    DSRunner, Mark77 and mattleg like this.
  8. Dec 29, 2020 at 1:10 PM
    auskip07
    Skip
    Atlanta, Ga
    got my wife a heated blanket for christmas and its usb powered im sure a portable battery pack would work on it
    DSRunner likes this.
  9. Dec 29, 2020 at 1:44 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Sorry about the hard times. It will get cold fairly quickly in the cab, especially the feet. If I recall, many parking lots in Canada have power outlets for block heaters, any chance you can find a location with power? A heated blanket off a block heater outlet would seem ideal. Lost cost and can be adjusted as the truck cools down. The only issue, I was thinking many of those outlets are timed cycled on/off.
  10. Dec 29, 2020 at 3:17 PM
    TaylorStreet
    TaylorStreet Member
    2019 White Tacoma Limited
    TRD Skid, MESO's, Remote Start,
    I took the passenger seat out of my 2001 Extend cab and it had very sufficient room to sleep in. I had a very thick down military mummy bag that I supplemented with a thin nylon sack inside the sleeping bag that I picked up at a camping store and added a military goretex combination poncho- bivy sack over everything. Underneath I used a thick moving blanket. I found it very comfortable. Lowest it ever got was 6 degrees farenheit. I could do it again, but don't think my girlfriend would be happy about that. (But I could!!!)
    Ronbo1, philth and Blackbeard83 like this.
  11. Dec 29, 2020 at 4:01 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Also using a CO or carbon monoxide detector is not a bad idea if you leave your vehicle running for extended periods.
    Silentshredr and stbear like this.
  12. Dec 29, 2020 at 4:38 PM
    fisherick
    fisherick Well-Known Member
    Rick
    Ma
    2016 Tacoma TRD OFF Road, AC, AT, Super White
    20" LED Bar, 265x75x16 S/T Maxx none
    Be sure to have a good insulated foam pad under you because you flatten out the sleeping bag insulation. Also a warm hat and socks, hot water bottle (Nalgene) and crack your windows.
    stbear likes this.
  13. Dec 29, 2020 at 8:21 PM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    A lot of great advice so far. Like some have said, get a good sleeping bag and sleeping pad for sure. Living in an area that can see -30° Celsius I would try to find the lowest temperature rated bag you can get and wear at LEAST 3 good layers of clothes(long shirt, long johns, pants, wool socks, hoodie, down jacket etc.) Definitely wear a warm hat/beanie as we lose a lot of our body heat from our heads. Also, a few warm blankets to go over you and the sleeping bag for the extremely cold nights/days.
    The Nalgene and boiling water is a great trick! "HotHands" Super warmers work great too.
    I also would not feel comfortable sleeping with the car running unless I am in dire need.
    Junkhead likes this.
  14. Dec 29, 2020 at 10:43 PM
    kjp4575
    kjp4575 Well-Known Member
    Portland OR
    2016 TRD Sport DCSB Prem Tech Package
    A lot of us have been in bad situations in our lives, so my hat's off to you for doing what you have to do.
    Anyway though... What most of these guys said, but some more ideas...
    First though I want to emphasize to definitely crack a couple windows at night. You don't want to get that moisture build up. It might not sound like a big deal but it'll get bad over time.
    I'm guessing money is a little tight right now, so if purchasing all the cold weather gear isn't an option, there are some good survivalist tricks that are free or close enough to free. Get yourself a couple of cheap tarps to line the seats and floor boards of the truck then crumble up dry leaves, dry pine needles, dry underbrush, stuff that's dry, etc... and sprinkle a thick layer of that stuff on top of the tarps but underneath you. It'll help insulate and if you get enough of it, it's pretty comfortable after the first night.
    Avoid alcohol, caffeine, and sugar. Those will all work against your body's natural ability to maintain temperature / sleep.
    Go to sleep with a full belly of food (I know this one will be controversial), it'll help keep you warm. On that same note, eat good food. A good meal is great for morale.
    When you got to go. Go. Don't try to hold it, you won't sleep well. Go outside or pee in a bottle. Your choice.
    Junkhead, Ronbo1 and SR-71A like this.
  15. Dec 30, 2020 at 1:20 AM
    #35
    Markcal
    Markcal Well-Known Member
  16. Jan 3, 2021 at 8:00 AM
    #36
    gundamzero
    gundamzero [OP] Well-Known Member
    Ontario, CANADA
    2017 TRD Sport Upgrade DBL CAB
    Thanks for all the tips guys. I will try the ones I can afford right now and report back.
    SR-71A and philth like this.
  17. Jan 3, 2021 at 8:05 AM
    #37
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    It's all about insulation. Your source of heat is you, so keep a sub zero "foil" lined bag along with some several blankets to create barriers of insulation.
    Blackbeard83 likes this.
  18. Jan 3, 2021 at 8:06 AM
    #38
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
    Never leave home without a trusted woobie
    CJH9980, Tacoma13_NC and Blackbeard83 like this.
  19. Feb 9, 2021 at 2:46 PM
    #39
    Markcal
    Blackbeard83 and philth like this.
  20. Feb 9, 2021 at 3:09 PM
    #40
    DSRunner
    DSRunner Well-Known Member
    I've camped in subzero temps a couple times without a heater and here's what I used....
    1. Sub-zero sleeping bag (~$100).
    2. Have some sock covered steel bottle, filled boiling water inside the sleeping bag. This can emanate heat for hours. ($10-50)
    3. 12v low draw heated blanket connected to a power station (i.e. Jackery) (~$50-100 for the blanket)
    4. Sleeping pad with a high R-Value. (~$100)
    Hope everything works out for you.
    SR-71A, Blackbeard83 and Markcal like this.
