Sleeping Platform - 2x6's or 2x8's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skincer, Apr 16, 2013.
  1. Apr 16, 2013 at 7:53 PM
    skincer
    skincer [OP] Member
    San Diego Area
    2013 Tacoma 4WD TRD Off-Road
    I've been searching around the forum and even though there are a million posts about building a sleeping platform, I can't find the answer to my specific questions. I just bought a 2013 Taco with the access cab. My bed has 2 notches in each side that look like they're made to accept a piece of lumber. The thing is, they're wider than a 2x6 (I had one around and tried it), but I'm pretty sure a 2x8 will be too wide. So, despite reading another post that said they're made for a 2x8, I don't think that can be the case. Is that correct?
    The other thing I don't get is that a 2x6 (or 2x8) is too thick. The notch appears to be about an inch deep, so a board that is 1.5" thick will be higher than the wheel wells and "ledge" that goes all along each side of the bed. So, is it best to just rest something on that ledge and forget about the notches? When I first saw the notches, I thought a 2x6 in each with some plywood resting on them and the ledges would be perfect, but I don't see how that will work out.
    Thanks.
  2. Apr 16, 2013 at 9:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    They were made for a 2 X 6. I wouldn't want it to rest on the ledges.
  3. Apr 16, 2013 at 9:36 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    sub'd!
  4. Apr 16, 2013 at 9:40 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    Tape measure?:notsure:
  5. Apr 16, 2013 at 9:46 PM
    IGO4LOW
    Zach
    Fullerton, CA
    Notch the ends so the 2x6 sits flush and use a support in the center.
    Closson likes this.
  6. Apr 16, 2013 at 9:50 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Just for clarification:
    2x6 = 1 1/2" x 5 1/2"
    2x8 = 1 1/2" x 7 1/2"
    TheDevilYouLove likes this.
  7. Apr 16, 2013 at 10:01 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    2x8's ripped to fit
    If you want sizes and angles I can figure that out for you tomorrow
  8. Apr 16, 2013 at 10:01 PM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Man, I thought I had problems! This is an intense woodworking issue! lol, j/k. /smartass.
    I think it's made for a 2x8 personally, although the 2x6 would fit readily but it would slide slightly which is fine for some/most applications.
    I just measured the ones on my 2013 dcsb and the notches are angled down to essentially 1x7. Personally I would do a bit of trimming to match the angle and use 2x8's and just have them stick .5 inch above the groove.
  9. Apr 16, 2013 at 10:06 PM
    majorhavok
    Mike in Cali..
    Also the top of the board isn't supposed to be flush with the lip above the groove/notch. Even if you used a 1x7 it's really only 3/4 so forget that. You could always make cuts to sides and bottom of a 2x8 to remove .5" on the bottom, and .25" on both sides (or .5 on one side...) if you NEEDED it to be flush.
  10. Apr 16, 2013 at 10:08 PM
    OZ-T
    Peter North
    British Columbia
    Flush is better then the ledge supports the plywood top
  11. Apr 16, 2013 at 11:24 PM
    majorhavok
    Mike in Cali..
    You are right, it's better but for a sleeping platform it shouldn't matter. The weight of the boards+plywood+ one or *two people should be more than fine in those notches. Although I guess it does matter how much the people weigh, but I wasn't going to ask. If a pair of 2x8's sag badly on a <4ft span, put in a center support and visit Jenny Craig or buy better quality dry 2x8's.
  12. Apr 16, 2013 at 11:27 PM
    OZ-T
    Peter North
    British Columbia
    1" aluminum :)
  13. Apr 16, 2013 at 11:28 PM
    majorhavok
    Mike in Cali..
    Also, I'm just guessing here, but I think they intended you to use two 2x4's in each slot. 2x 1.5x3.5" actual boards would fit perfectly there with no trimming... unless you wanted flush for max load capacity.
  14. Apr 16, 2013 at 11:29 PM
    OZ-T
    Peter North
    British Columbia
    Cut on saw
  15. Apr 16, 2013 at 11:30 PM
    OZ-T
    Peter North
    British Columbia
    Why Jimmy
  16. Apr 16, 2013 at 11:31 PM
    majorhavok
    Mike in Cali..
    Starts getting pricey! Minimum $600 USD for solid bar 6061.
    And do you say it U.S. style or add a bit with the British style "Al-yew-min-e-um"?
  17. Apr 16, 2013 at 11:32 PM
    OZ-T
    Peter North
    British Columbia
    I say it properly
    I didn't mean solid stock
  18. Apr 16, 2013 at 11:33 PM
    OZ-T
    Peter North
    British Columbia
    I'm going to bed , I'll rip a piece to fit tommorow and post a pic
    You take it from there OP
  19. Apr 16, 2013 at 11:39 PM
    majorhavok
    Mike in Cali..
    I figured you would add inappropriate syllables you Brit-can. All for the queen I guess.
    U-channel? H-Bar, T-Bar, I-Beam? Square? Good luck finding something to fit a 1x7 slot.
  20. Apr 16, 2013 at 11:42 PM
    majorhavok
    Mike in Cali..
    I get that. :) I do own a compound miter saw.. even has a little useless laser for "sighting" the target.
    Making these cuts is almost a dremel job though..
