Sleeping Platform - 2x6's or 2x8's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skincer, Apr 16, 2013.
  1. Apr 17, 2013 at 5:37 PM
    #41
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Being the boss has it's perks :cool:
  2. Apr 17, 2013 at 5:40 PM
    #42
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Ups and downs , haha
  3. Apr 17, 2013 at 5:41 PM
    #43
    Pugga
    Massachusetts
    Not to get off topic, but I wish I had the balls to go out and start my own company. Working for a large company certainly has it's perks though and not having to worry that every decision you make directly affects your livelihood just wouldn't work well for me :eek:
  4. Apr 17, 2013 at 5:42 PM
    #44
    OZ-T
    Peter North
    British Columbia
    Yeah , it can be a roller coaster , lol
  5. Apr 18, 2013 at 12:00 AM
    #45
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    IMO the cutouts are simply made for supporting sheets of plywood drywall etc. That is why they made them only 1 inch deep, so all the weight is on the cross beams and not rubbing on the box ledge.
    If I were making a sleeping platform or ... I think two 2X6's and a 3/4 inch sheet of plywood would be quite enough.
    BigRus75 likes this.
  6. Apr 18, 2013 at 12:10 AM
    #46
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    would 5/4 deck board work? It has the right height I think, and rounded edges?
  7. Apr 18, 2013 at 5:52 AM
    #47
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    Thought about using ipe? Very dense wood, structural values close to that of steel. I'm using it as the surface of my deck - amazing stuff. Beautiful too.
  8. Apr 18, 2013 at 6:56 AM
    #48
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    I made a deck out of Brazilian Ipe, super hard and heavy wood, i used 2 diablo saw blades to finish the project. Beautiful wood.
  9. Apr 18, 2013 at 8:25 AM
    #49
    OZ-T
    Peter North
    British Columbia
    Yes
  10. Apr 18, 2013 at 8:26 AM
    #50
    OZ-T
    Peter North
    British Columbia
    The ledge and the wheel wells are all level , more surface area , less localized rubbing
  11. Apr 18, 2013 at 8:27 AM
    #51
    OZ-T
    Peter North
    British Columbia
    Any strong grained wood will work in a 1" thickness IMO
  12. Apr 18, 2013 at 9:00 AM
    #52
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    What is ipe
  13. Apr 18, 2013 at 9:07 AM
    #53
    Pugga
    Massachusetts
    It's a very hard, very resilient type of wood. It's typically seen on boardwalks but I have also seen it used as a rainscreen (wouldn't recommend that application, it was a PITA).
    Ipe :D
  14. Apr 18, 2013 at 9:20 AM
    #54
    BostonBilly
    Easton
    Thanks for the link dick. :quickdraw:
  15. Apr 18, 2013 at 9:25 AM
    #55
    Pugga
    Massachusetts
    I'm like Verizon customer service, you'll get your answer but you'll want to strangle the guy on the other end of the line in the process :)
  16. Apr 18, 2013 at 9:46 AM
    #56
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    Mine is 1" pine and it works fine. It's a little bouncy, but not much. Also, I am only using 5/8" plywood on top.
  17. Apr 18, 2013 at 10:19 AM
    #57
    Hart41983
    Hart41983 Member
    I used 2x6's notched to sit flush. Then 5/8" plywood in two pieces split lengthwise of the truck, so I could use single platform if needed. On one side of the platform I added a 3-4' (not sure exact length) 1"x6" centered to have 3" of board on either side of the platform edge. Measured this board to fit perfectly between the 2x6"s. This sured of the platform and keeps the 2x6's from sliding. Then of course add the shag carpet
  18. Apr 18, 2013 at 10:21 AM
    #58
    On An Island
    David
    Houston-ish
    Shag carpet? Sexy. :D
  19. Apr 18, 2013 at 12:51 PM
    #59
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    will use for future camping.
  20. Apr 19, 2013 at 11:54 AM
    #60
    oZmonKey
    oZmonKey Big Metal Hubajube
    Northern Colorado
    Black 98
    Unknown Spacer Lift.
    I'll measure later, but what is the side to side length for reference?
