Sleeping Platform Through Window Into Cab - Am I Crazy?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by COTACOOO, Dec 15, 2019.
  1. Dec 15, 2019 at 6:05 PM
    #41
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    That's what I am thinking. This wouldn't work for me. But perhaps it will for the OP.
  2. Dec 15, 2019 at 6:12 PM
    #42
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Police will come knocking on your CAMPER SHELL.
    GreyBaldTaco likes this.
  3. Dec 15, 2019 at 6:27 PM
    #43
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I had a canopy with no front window, it had a rubber seal. It worked pretty well. The seal wore the paint off the cab due to them moving independently. I still had a window in the cab. The seal leaked a little but it drained out since the seal flared out larger than the window.
  4. Dec 15, 2019 at 6:38 PM
    #44
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
  5. Dec 15, 2019 at 6:53 PM
    #45
    markgphoto
    markgphoto Well-Known Member
    Mark
    Middle Tennessee
    2020 Tacoma ArmyGreen TRD Pro
    I had a shell that did not come with a front window, just an opening with a rubber boot. It was on an '86 Toyota pickup. Drove it 330K+ for 20 years. Never leaked. It shouldn't be a problem to simply remove the shell window and cab rear window to add a permanent boot. Simple DIY project. In the RV world, they use accordion style boots between the cab and camper on van based RVs. As far as sleeping height, you'll have to get a highrise shell, such as a Leer 122.
    Steves104x4 likes this.
  6. Dec 15, 2019 at 7:01 PM
    #46
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The “seat delete” is a popular thing in the double cabs. If you pull the passenger seat, and lay down a removable platform, a normal height person can sleep in there. It’s actually a lot longer than the short bed when you consider the foot well.
  7. Dec 15, 2019 at 7:48 PM
    #47
    Dravnx
    Dravnx Well-Known Member
    jeff
    Santa Rosa, Ca
    2018 SR5
    I had a rubber boot to seal between the cap and the cab on another truck. The constant movement between the bed and the cab caused the boot to rub on the cab. It eventually wore the paint off the cab. I'll never do that again.
  8. Dec 15, 2019 at 8:09 PM
    #48
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Do you know how many Naugas died to make that? I am outraged!:rofl:
  9. Dec 15, 2019 at 8:46 PM
    #49
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Only 4.3 inches, not 6 inches.
    Long bed is 73.7 inches.
  10. Dec 15, 2019 at 8:55 PM
    #50
    OregontoBajaCA
    2025 OR DC iF Max
    13.2 inches longer than the short bed! It’s the same for the wheelbase.
    1.2 inches is a lot to some people.
  11. Dec 15, 2019 at 9:08 PM
    #51
    OregontoBajaCA
    2025 OR DC iF Max
    Toyota SofTex synthetic leather, similar to Naugahyde.
    Nauga, tastes like chicken.
  12. Nov 18, 2020 at 5:04 AM
    #52
    Tao96
    Tao96 New Member
    How about a breezer window (~$300) plus a boot/seal/gasket and remove window on shell. The breezer closes back up with removable middle section for improved security and weather proofing of cab.[​IMG]
    cosmicfires and WarrenG like this.
  13. Nov 18, 2020 at 6:54 AM
    #53
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    Isn't that standard on the Tundra? My thoughts are it sounds like you either want a Tundra or a 4R with the back seats folded down.
  14. Nov 18, 2020 at 7:52 AM
    #54
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    flex seal!
    but really should probably get a truck with a bigger bed. or just sleep from left corner to right corner
    cosmicfires likes this.
  15. Nov 18, 2020 at 8:38 AM
    #55
    Sungod
    Sungod Well-Known Member
    St Augustine
    I'm guessing Tao is pushing his product by signing up today and resurrecting a year old post.
    In any case this reminds me of the 80s when slide-in campers were the rage in Cali. There were companies that would make a vinyl boot to go between your camper and the cab so you could easily access the camper while driving. Turned our camper into a motor home.
