Sleeping with tailgate down and staying warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HansLanda, Mar 15, 2021.
  1. Mar 15, 2021 at 8:19 AM
    HansLanda
    HansLanda [OP] Well-Known Member
    I’ve got a short bed with a camper shell, and I’m over 6’ tall, so I need to sleep with the tailgate down. We made a makeshift barrier with a hammock over the back, strapped to the frame. It worked, we were warm, but there were some air gaps, and it was hard to crawl in and out.
    What other ways have you kept your feet warm? I was thinking of making something from Reflectix insulation, but it doesn’t pack down as small as a hammock.
  2. Mar 15, 2021 at 8:30 AM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    You can use the right sized tarp. If you have the 2 t-handles on either side attach/wrap around those with string rope or zip ties. Then just drape it over. Time to get out just raise back window and slide on out. It not pretty but it works and easy on easy off. If it's windy you can always weight the bottom with some rocks tied onto bottom
    Edit- this would be my cheap and easy fix but if you plan on sleeping in your bed alot I'd go with a tent type thing like others posted below. If only sleeping in the bed a handful of weekends a year personally I'd go with a tarp. Makes it more interesting and exciting on those weather days (wind/rain/snow) that most people don't like. I get excited about the crazy weather days though so....
  3. Mar 15, 2021 at 12:41 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    How about something like this?
  4. Mar 15, 2021 at 1:06 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
  5. Mar 15, 2021 at 2:31 PM
    G-shock!
    G-shock! Well-Known Member
    OC TACOMAN
    Orange County
    2GTRD4L
    Fox 2.0 frt/resi rr PolyPerf. UCAs
    Is this a medium or large DAC? TIA
  6. Mar 15, 2021 at 2:32 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
  7. Mar 15, 2021 at 4:46 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Not my truck but I do own one and mines the medium I believe.
    G-shock![QUOTED] likes this.
  8. Mar 15, 2021 at 6:21 PM
    HansLanda
    I should have clarified. I'm looking for more of a DIY solution, similar to the hammock, but better. It packs down incredibly small, which is nice.
    Maybe I'll just experiment with cutting a more windproof tarp, and securing it to the tailgate with velcro or something.
  9. Mar 15, 2021 at 6:38 PM
    Offthewall
    Offthewall Well-Known Member
    Southern OR
    12 tx pro
    That’s why I’m here
    I have used magnets with a screen in my 4 runner during the summer. Would probably work with a hammock. Home Depot sells pretty decent ones. You could use them to hold it to the tailgate
  10. Mar 15, 2021 at 6:50 PM
    DiscoYaker
    SE USA and Alaska
    A tarp is useful for many other things as well. I ve actually used a tarp before like I said in post #2. I have a 6' bed in both of my trucks and I'm shorter than that but a few times in heavy rain I've opened tailgate and stashed stuff I didn't want getting more wet. I used a tarp (with tailgate window down) to keep things dryer. In super heavy rain I make sure truck is slanted at least slight downhil so rain will drain towards front not back towards tarp.
    BTW I wouldn't cut the tarp unless you re-sow the seams. Also pretty much every tarp is 'wind proof'. The grommets (tie down points) on the blue/grey tarps most people have tear pretty easily but you can use a small rock. Wrap the corner of tarp around small Rock then tie a small gauge rope around that and you have a much stronger tie off point. If I didn't say that to were you can understand I can take a few pictures if interested. Sometimes I'm not great at explaining via text
  11. Mar 15, 2021 at 6:54 PM
    DiscoYaker
    SE USA and Alaska
    Just to add- I usually keep a tarp in my truck all the time. There are so many scenarios that they can be useful. Unfortunately we used one as a stretcher one time,, but worked well and weighted new to nothing on the hike in.
  12. Mar 15, 2021 at 6:57 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  13. Mar 16, 2021 at 12:07 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    Go to your local golf shop and buy one of the mini propane heaters that are used for golf carts. You can buy the little
    Coleman propane containers pretty much any where. Place it on your tailgate facing in towards you.
  14. Mar 16, 2021 at 12:46 AM
    241240 Sir Lurks-A-Lot
    09 base double cab 4.0 MT
    Sat my fat rear end in it.
    I don't have a shell. A long time ago I took some scrap 1x2 and made a crude frame to hold a tarp up over the bed...One end of the 4 "rafters" rested on top of the cab, the other end rested on a u-shaped frame that I clamped to the rear bed rails. The tarp I had was large enough to stretch out and make a dry patio behind the truck too.
    It worked surprisingly well.
  15. Mar 16, 2021 at 12:53 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    That's it, you'll just have to buy a long box or a pull behind camper:yes:
  16. Mar 16, 2021 at 12:56 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You could probably use a bed extender to keep whatever you use for fabric from reducing the amount of space you have for your feet.
    DiscoYaker and theolee like this.
