Sleeved fog light housing - How to
Discussion in '2nd Gen. Tacomas (2005-2015)' started by T-rev, Jul 25, 2010.
  1. Jul 25, 2010 at 10:14 AM
    T-rev
    T-rev [OP] Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    This is a step by step walk through of how to black out the fog light housing, or what I like to call "sleeve" them. It is very easy mod that is also inexpensive. First off, the materials needed are as follows: Soapy water, hand towel, electrical tape, 11oz can of black Plasti-Dip undercoating spray, wide painters tape, and newspapers.
    Start by taking the fog lights out of their housing. From under the front bumper you can spot the housings. Disconnect the bulbs by turning the light socket 1/4 turn counterclockwise. Now find the adjusting tab and press in on the clips that push out, once they've cleared start to push the fog light out just so the clips aren't holding it back anymore. There are two more tabs on each side horizontally placed, push these in and remove the fog light.
    Once both fog lights have been removed, make sure you thoroughly wash the area with soapy water. It needs to be perfectly clean. Dry with a small hand towel, it needs to be completely dry for the undercoating to adhere.
    For the next step I used electrical tape just for the elastic nature, it allowed me to create smooth, clean curves. Using the tape I slowly formed and fitted it until I was happy with the edge. For refrence, in the fog light housing there it a slight contour a couple inches out from the fog light. Following this will make it a lot easier then trying to create your own curves and match them. Keep in mind you can go as far out as you would like.
    Make sure you have readied the Plasti-Dip by shaking it according to the cans suggestions. Make sure you cover the front of the truck with newspaper or something else, I did about a 3' radius from where I was painting. Start applying the Plasti-Dip in small, even coats. I did about 3-4, or just until it's completely covered. ONLY DO ONE LIGHT HOUSING AT A TIME, Plasti-Dip dries very fast, time inbetween coats should be minimal. I never waited over 30 seconds. Once you have done all your coats start pulling away all the covering you used. Carefully pull the tape you used to create your edge as soon as you can. The undercoating will create a bond between the housing and the tape if you wait too long and it won't give you a nice, clean edge. Check for any over spray, a moist cloth will be able to take any off. Once you've completed one side, follow the same procedure for the other.
    The undercoating dries fast but will stay tacky for while, wait for it to be completely dry before pushing the fog lights back in. 24 hours should be more than enough time, better safe then sorry. This is a very easy mod, even easier then the BHLM. Prep is everything in this mod so make sure you take your time with it.
    Here is what it looks like all put back together. Good luck!
    I will upload some pictures of the process when my camera is charged.
  2. Jul 25, 2010 at 10:23 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Goes really good with your truck. Good job!
  3. Jul 25, 2010 at 10:42 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    sweet and unique
  4. Jul 25, 2010 at 10:46 AM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Looks awesome bro!
  5. Jul 25, 2010 at 12:17 PM
    ycart1201
    ycart1201 Well-Known Member
    Nathan
    Oregon
    2016 DC TRD Sport 4x4 - My build is underway
    Current Project: 2016 DC TRD Sport 4x4
    Looks great!
    Nathan
    ycart1201
  6. Jul 25, 2010 at 12:20 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    Nice...:thumbsup:
    ..been wanting to do this for a while
  7. Jul 25, 2010 at 12:33 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Nice write up T-rev!! I did exactly as he wrote when I did mine.;)
  8. Jul 25, 2010 at 12:34 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I love it.
  9. Jul 25, 2010 at 1:34 PM
    05PreRunner
    <-(714)-> SO-CAL
    Alright.... I'm officially convinced....
    Gonna be doin this SOON!
  10. Jul 25, 2010 at 3:51 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    This really matches the black headlight mod. I'm doing it when I get a few bucks.
  11. Jul 29, 2010 at 6:22 PM
    samhain
    samhain Well-Known Member
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    Love this mod. Where did you get the Plasti Dip and do you think it would work well covering the lower bumper?
  12. Jul 29, 2010 at 10:00 PM
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
    t-rev,
    nice looking truck! I saw an old post about the sleeved fog lights and have wanted to do it for a while.
    I think it matches the BHLM real good. Do you think it would look good with the paint going all the way out to the front of the bumper surface? I'm not sure if it would be too much black or if it would make it stand out more.
  13. Jul 29, 2010 at 10:02 PM
    05PreRunner
    <-(714)-> SO-CAL
    x2!
    Im debating on doing the same...
    :popcorn:
  14. Jul 29, 2010 at 10:03 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Nice. WOnder if I should do it on my MGM. would probably make my yellow fogs blend in a bit more.
  15. Jul 29, 2010 at 11:20 PM
    pinktaco808
    pinktaco808 Hot Steppa
    where is it
  16. Jul 29, 2010 at 11:30 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    sticky!!!! please sticky!
  17. Jul 30, 2010 at 12:25 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well someone do it so we can take a look!!!:p
  18. Jul 31, 2010 at 3:46 PM
    T-rev
    Tempe, AZ
    2017 TRD Offroad
    Thanks! Yeah it will look good though. I was just worried about taping around the crease we have in our front bumpers, I wanted them to turn out perfectly symmetrical. Here's a link to the thread that gave me the idea for this. http://www.tacomaworld.com/forum/x-runners/51448-fog-light-area-mod.html
  19. Jul 31, 2010 at 5:25 PM
    IluvTEA
    South Dakota
    That was the thread I saw a few months ago. I was trying to find it.
    Yeah I think dmbfan73's version would be harder to tape off, but I think its less noticeable your way. Hmm, not sure if I want it easier and more subtle or more difficult and more noticeable.
    Did you need to sand the area down before painting?
    Thanks again for the great writeup!! Once I make up my mind, I'll do this mod!
  20. Aug 1, 2010 at 7:16 AM
    T-rev
    Tempe, AZ
    2017 TRD Offroad
    That's exactly what I thought, I'm very happy with the more subtle look as my truck already has a ton of black accenting. I don't want to go overkill on it. And no sanding required, just follow the write up!
