Sleeving 1gr help
Discussion in 'Performance and Tuning' started by xrunnahnj, Oct 8, 2021.
  1. Oct 8, 2021 at 12:56 PM
    xrunnahnj
    xrunnahnj [OP] Member
    06 XRunner
    URD stage 3 sc and my motor, just rebuilt, blown again. It was built with larger pistons. I don’t know the details of the build because it was a huge issue to get my truck back. I know it was built with larger piston because the machine shop said he needs pistons 30 over. Whatever that number means. The crank was grounded down already so I just ordered a new oem crankshaft.
    I have searching for motors and they’re not cheap. I know going into this I’ll be spending 4-5k here in jersey.
    Pistons 8-900
    Rods 8-900
    Bearings 3-400?
    Misc gaskets/head studs etc 1500?
    Labor is 1500 flat.
    I will be boosting it again for sure.
    Sleeve kit is $1500
    Here my question, should I spend the money on sleeving the block if it will be able to handle stage 3.
    Do I spend 3k on a used motor and step down to stage 2?
    I’ve already lost 6k on the first build. I don’t want to do this a third time.
  2. Oct 8, 2021 at 1:04 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  3. Oct 8, 2021 at 1:22 PM
    xrunnahnj
    06 XRunner
    I actually was messaging him and never got to asking him.
  4. Oct 8, 2021 at 1:32 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i dont see why a correctly built and sleeved motor couldnt handle that stage 3. my blind guess would be incorrect assembly or not proper break in. best of luck brother.
  5. Oct 8, 2021 at 1:40 PM
    xrunnahnj
    06 XRunner
    When it was first built, it wasn’t sleeved. It was bored .020”. Now I have to find pistons that are .030” or sleeve the block or get another motor
  6. Oct 8, 2021 at 1:52 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @Torspd has more 1st hand experience than anyone. he's also willing to help people. you'll get it going strong soon.
  7. Oct 8, 2021 at 2:05 PM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    :popcorn:
    What broke? How much boost were you running?
  8. Oct 8, 2021 at 2:10 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I though you couldn’t bore the 1GR ….
  9. Oct 8, 2021 at 2:10 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    correctly assembled 1grfe should hold 20psi. i doubt urd would make that.
  10. Oct 8, 2021 at 2:10 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Not if you're sane.
    Torspd likes this.
  11. Oct 8, 2021 at 2:11 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    oh. yes you can. with the right monies these motors can turn 800hp. cant do that with stock specs.
  12. Oct 8, 2021 at 2:23 PM
    xrunnahnj
    06 XRunner
    Main bearing and oil pump failure. There were no gauges because it was boosted the day before. Barely 10 miles. My dumbass decided to conduct a spirited launch and spun a bearing and caused oil pump failure. Oil filter was bone dry.
  13. Oct 8, 2021 at 2:25 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    So the oil level was low? Are you using the 4x4 deep pan?
    You said the crank was ground already, did you also spin a bearing before?
  14. Oct 8, 2021 at 2:31 PM
    xrunnahnj
    06 XRunner
    was using the stick oil pan. After it blew again I bought the coupe spacer.
    Yes I spun a bearing. Oil level was low and I didn’t know. I barely drove it
  15. Oct 8, 2021 at 2:42 PM
    Sharpish
    Brian
    So how does that work? A few thousandths and your into the aluminum block
  16. Oct 8, 2021 at 3:26 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    there is a very specific break in period. fluids and rpm for 500miles. that should have been made very clear by your engine builder. if you ignored....if they failed to tell you shame on them.
    cryptolyme likes this.
  17. Oct 8, 2021 at 3:29 PM
    xrunnahnj
    06 XRunner
    So I did run it about 5-600 miles before boosting.
  18. Oct 8, 2021 at 3:34 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    hmmm.. nothing should fail like that twice done correctly. im just throwing ideas out to help you diagnose. theyre price is too cheap for comfort. i just today got a quote for 2300 to put my new cams in. just camshafts.
  19. Oct 8, 2021 at 3:35 PM
    xrunnahnj
    06 XRunner
    I don’t think I need to build anything but the bottom end. Stage 3 to play all day. Nothing else needed
  20. Oct 8, 2021 at 3:36 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    or the tuning is fucked. @JustDSM is an absolute wizzard. he may have some help. super awesome guy.
