Sleeving 1gr help
Discussion in 'Performance and Tuning' started by xrunnahnj, Oct 8, 2021.
  1. Oct 25, 2021 at 8:29 AM
    #41
    xrunnahnj
    xrunnahnj [OP] Member
    06 XRunner
    A lot of this info is like reading Japanese. I know little of what you guys are relating.
    I was told by Darton they’d sleeve the block. Reason is for the stage 3 sc.
    if it’s not worth the cost and hassle, might as well just build the motor with better internals and keep it n/a?
    Picked up a motor from @mightytacoman drop in ready. I’ll use that for now till I figure what I should do. I am planning to sc it. Stage 2?
  2. Oct 25, 2021 at 8:30 AM
    #42
    xrunnahnj
    06 XRunner
    As far as tuning? I’m just using what’s in the urd box
  3. Oct 25, 2021 at 9:55 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Don't sleeve the block that has damaged main journals. Worthless. They would have to be machine true, then bearings would have to be sourced. That will likely be the harder part.
    However, if oversized main journal bearings can be found, then it can work. I find this a much lower percentage a possibility.
  4. Oct 25, 2021 at 10:19 AM
    #44
    xrunnahnj
    06 XRunner
    I have a spare block as well
  5. Oct 25, 2021 at 10:50 AM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Perfect
  6. Oct 25, 2021 at 10:55 AM
    #46
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    not rocket science
    Sleeving REMOVES metal from an already weak block
    blocks move around even when stock
    they Move even more when overbored or sleeved..................resulting in components
    MISaligning & tolerances distorting
    U can handle that
  7. Oct 25, 2021 at 11:40 AM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The sleeves job completely removes the oem cylinders. Which are of the open deck design. The Darton M.I.D. (Modular Intergrated Deck) then fit tightly in the block acting like a closed deck block. Adding rigidity.
  8. Oct 25, 2021 at 3:06 PM
    #48
    ROAD DOG
    FEW
    I understand what U say
    not in ANY attempting to undercut what U do
    any reputable engine will tell U a fact in reality
    a brand new virgin block moves around !!
    a block bored or sleeved moves around
    most engine builders realizing thats a fact in reality
    rather deal with a seasoned block...................brand new out the crate AINT SEASONED
    its a minor thought concept removing metal weakens the block
    many seldom run engines MAXED out for a few seconds at a time
    endurance raced for years
    getting ANY engine to hold together for 6......8 ........12 & 24 hours this is a MAJOR Consideration
    E V E RY component reaches heat soak street engine NEVER gets to
    that a drag engine NEVER gets to..................EVER
  9. May 7, 2025 at 4:22 AM
    #49
    xFunner
    xFunner Member
    North East
    2012 Black Tacoma Xrunner
  10. May 7, 2025 at 7:19 AM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Best way to get information is to contact him through YouTube.
