Sleipnir's FURD BURD Bigfoot thread: Oh chit we have proof of life!
Discussion in 'Other Builds' started by Sleipnir, Jul 27, 2018.
  1. Mar 9, 2021 at 1:12 PM
    #1861
    Sleipnir
    Sleipnir [OP] Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Just dropped it off. They’re gonna call me tomorrow to swing by and show them what I want when it’s on the rack.
  2. Mar 10, 2021 at 9:54 AM
    #1862
    Sleipnir
    I'm a horse
    Asgard
    Swung by the shop earlier to show them how I want the opr mounted and they already had the pan off ready to drop the new one in. They said once the RTV has had 24 hours to dry it’ll be ready for pick up hopefully Thursday if not Friday
  3. Mar 11, 2021 at 10:26 AM
    #1863
    Sleipnir
    I'm a horse
    Asgard
    Picked the truck up and it feels great. I could feel the turbos dragging (?) Before when I stepped on the gas. Now it doesn't drag and power picks up quick. Once this is tuned it's going to be insane.
    The OPR was mounted in a great spot and they routed the hoses exactly how I would. Love how small and compact it is.
    [​IMG][​IMG][​IMG]
    First start and the OPR was 40 psi at cold start and idles so much smoother! Will post a cold start tomorrow morning.
    https://youtu.be/oFUgVuObOIc
    Once I got to temp oil pressure looks so much better and the truck loves it a lot. Like I said before idle is amazing!
    https://youtu.be/F7RDIPyjiqw
    Just need to drive it a while and get the smoke out of the system or just drop it and clean it out. Overall I'm super pumped with the work done and seems to be the fix I needed.
  4. Mar 12, 2021 at 8:52 AM
    #1864
    Sleipnir
    I'm a horse
    Asgard
    Small fix but huge difference. My gas door was broken because I fiddle to much. Bought a new door and a upgraded door pin. Looks much better
    [​IMG][​IMG][​IMG][​IMG]
    MattCowsmasher and Front sight like this.
  5. Mar 12, 2021 at 2:22 PM
    #1865
    Sleipnir
    I'm a horse
    Asgard
    My tuner had me throw V17 tune on the truck. Baseline is v14. Made 62#/min, 4.75* of timing, over 22psi and 0 wastegate % :rofl:
    I made 20# of air with a click of a button :D
  6. Mar 13, 2021 at 12:00 PM
    #1866
    Sleipnir
    I'm a horse
    Asgard
    So chasing some issues down with a buddy and found a nice vacuum leak. Was on the phone with @Boostking trying to figure out the smoking issues that came back and saw it. We jbwelded it and hoping for the best. I think this was a big problem so let's see if the smoke stops now and the boost is controllable.
  7. Mar 13, 2021 at 12:07 PM
    #1867
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Stomping out one gremlin at a time. I’m looking forward to seeing it all come together for you.
    MattCowsmasher and Sleipnir[OP] like this.
  8. Mar 13, 2021 at 12:50 PM
    #1868
    Sleipnir
    I'm a horse
    Asgard
    Thank you sir. Hopefully this is the last one
    MattCowsmasher likes this.
  9. Mar 14, 2021 at 6:54 PM
    #1869
    Sleipnir
    I'm a horse
    Asgard
    So after fixing the vacuum leak yesterday and going for a test run the truck still smoked. I came home and decided to put my catch routing back to stock. Passenger side is pcv to can to intake manifold. Before it was to the intake. The driver is still the same and what is recommend.
    Drove it the same route as before and 0 smoke. I did notice though smoke under the hood and oil from the breather blew through the filter spraying oil. What I forgot was the pcv was gutted so I am going to the dealer tomorrow to pick up a new one. Will test for a few days and see where it goes.
    Responseness on the turbos feel quicker with the vacuum fixed and the routing right. Hopefully this is THE fix.
  10. Mar 15, 2021 at 9:02 AM
    #1870
    Sleipnir
    I'm a horse
    Asgard
    Well I'm still smoking but only at idle after a while and when I rev the motor it stops. I think the exhaust is full of oil so I'll drop it today when it cools down and clean it out really good. Hopefully I don't have to drop the down pipes too
  11. Mar 15, 2021 at 5:02 PM
    #1871
    Sleipnir
    I'm a horse
    Asgard
    Bingo. It's at hot idle and I now know why.
    https://youtube.com/shorts/SIoshFtgSLg
    There was so much oil trapped in the exhaust that I decide to drop the whole thing and clean it. I didn't quite know what I was getting into. Unbolted the catback first and went to see what the exhaust looked like. I also wanted to see if it would smoke in the downpipes too. That would tell me if my day was long or short. Unfortunately, it wasn't short. Here's a clip of the video but I have to say it sounds nasty in person.
    https://youtu.be/MgT38pfT_eM
    So I had to drop the hole exhaust and clean it out. I went to the auto parts store and bought GUNK gel degreaser and a couple cans of original. Sprayed the entire exhaust and let it sit for an hour. A neighbor let me borrow their pressure washer and here are the results. I have header wrap coming because I ripped the driver side downpipes wrap. Going to let it dry and then tomorrow hook it up and see if it smokes still.
    https://imgur.com/a/eXhAPRJ
    While I had the exhaust off I figured I'd inspect the back of the turbos. 0 shaft play and looks ok
    https://imgur.com/a/m0vOGnC
  12. Mar 15, 2021 at 6:06 PM
    #1872
    Sleipnir
    I'm a horse
    Asgard
    Torspd and MattCowsmasher like this.
  13. Mar 16, 2021 at 6:14 PM
    #1873
    Sleipnir
    I'm a horse
    Asgard
    Definitely breaking up on the top but it’s making like 30psi :eek:
    FastEddy59 and MattCowsmasher like this.
  14. Mar 16, 2021 at 6:45 PM
    #1874
    Sleipnir
    I'm a horse
    Asgard
    So got the exhaust mounted back up and still some smoke. The more I drive it though the better it gets. I did test rerouting the catch cans back to the way I had them (gutted pcv to can to I take) and the turbos don’t smoke.
    Here’s with the can rerouted
    https://youtube.com/shorts/ZZylXiOQlnA
    Here’s after I ran it the first time being put back on. It smoked but you could tell it was thinning out
    https://youtube.com/shorts/3ML50eN8G-s
    Here’s after run two getting it hot and letting it idle for 15 minutes
    https://youtube.com/shorts/kRz8XZ-DDjI
    and here’s after testing V20 tune. This time is hot and definitely needs work. Brett and I are going to do some work tomorrow and go back to baselines. Once we have a controlled baseline we’ll add power. Right now the wastegates are doing this weird spike thing when we try to keep them at 0%
    https://youtube.com/shorts/M5oZtbzK_v8
  15. Mar 16, 2021 at 9:40 PM
    #1875
    Sleipnir
    I'm a horse
    Asgard
    I can hear my Turbosmart BOV leaking at high WOT so I ordered a Tial Q 50mm. Let’s see if this fixes the leak.
  16. Mar 17, 2021 at 6:36 AM
    #1876
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You had a busy past few days! I was curious if your exhaust was coated in oil. I can't remember the specifics, but wasn't that from back before you had most recently shipped it put?
    Have to listen to the videos in a few.
    Sleipnir[OP] likes this.
  17. Mar 17, 2021 at 7:13 AM
    #1877
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What is this melted piece here?
    Sleipnir[QUOTED][OP] likes this.
  18. Mar 17, 2021 at 7:29 AM
    #1878
    Sleipnir
    I'm a horse
    Asgard
    Yea I’ve had smoking issues since I picked it up originally back in 2020. It’s all because the turbos were getting too much oil.
    It’s a secondary vacuum reservoir. The 11-12 trucks had BOVs in the turbos and this was used as a secondary vacuum source.
  19. Mar 17, 2021 at 8:56 AM
    #1879
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So it is basically a vacuum block then? No internal diaphragm, correct?
  20. Mar 17, 2021 at 9:48 AM
    #1880
    Sleipnir
    I'm a horse
    Asgard
    Correct and made a heck of a boost leak
