Slider input help?
Discussion in 'Off-Roading & Trails' started by Masada, Oct 29, 2009.
  1. Oct 29, 2009 at 8:55 AM
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I have chosen to go with avid off road sliders but I have a few questions.
    So can anyone see a problem with getting bolt on sliders and welding them on?
    I'm thinking doing this so it would be easier to mount them and not have to worry about not getting the positioning right and then weld them on instead of just bolting them up.
    lastly, anyone have an opinion about angling the sliders when they go on or keep them flat?
    like this: ___ or __/
  2. Oct 29, 2009 at 9:08 AM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    That's not a bad idea. Bolt on and put some small tack welds around them. As far as the angle goes I prefer a little angle, just for looks only. I'm thinking you'll have more protection straight out?
  3. Nov 10, 2009 at 4:53 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    I angled mine for better clearance (if your truck Leans your flat sliders point straight down at the ground) and also for better protection of the rocker panels which often get damaged
  4. Nov 10, 2009 at 6:36 PM
    Masada
    Taylor
    Laveen, AZ
    My Avid Off Road sliders will be done end of the week, they will be weld on. I will post pics as soon as I paint them and have them put on.
  5. Nov 10, 2009 at 6:57 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    they bounce off trees better:D
