Slider Install Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Conex, Sep 24, 2013.
  1. Sep 24, 2013 at 6:54 PM
    Conex
    Conex [OP] Well-Known Member
    First off....2013 DCSB. I was mocking up my sliders today to mark for drilling. Passenger side went as planned, but on the drivers side frame where you are supposed to bolt through the factory frame holes I have brake line clips in all of them. If I push the clips in and put in the bolt, the brake lines are flexed up tight against the back of the bolts which is not a good thing at all. Anybody else run into this?
    BTW I am waiting on a call back from Allpro but was hoping to get back under the truck in the morning.
  2. Sep 26, 2013 at 12:46 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    I made my own sliders that bolt to factory holes. You have to bend the brake lines to clear the nut on the inside of the frame
