Slider Mount Angle Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdkeller, Sep 21, 2009.
  1. Sep 21, 2009 at 8:32 PM
    jdkeller
    jdkeller [OP] How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    So Im hopefully going to finally get my sliders welded on tomorrow. I had a question. Right now, my truck probably sits 1/2" higher in the rear. I might get spindles in the future so my truck might end up being 1/2" or so higher in the front. So an inch difference. If I weld them on right now, do they get welded on parallel with the frame? of the body? Or is it the same? Is the body always going to be parallel with the frame whenever I do suspension changes?
    Do yall get what Im saying? I dont want the sliders to end up being not parallel with the body and look off.
  2. Sep 21, 2009 at 8:39 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I imagine if you weld them even with the frame it would be alright. I wouldnt think you would want them not paralell with the frame, I think that would look off, if this is what you are saying.
  3. Sep 21, 2009 at 8:40 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    After knocking some sense into me I realized that the frame and body will always be parallel unless you do something like a body lift. Correct?
  4. Sep 21, 2009 at 8:41 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Well I want them parallel with the body. You know so it looks like this =
  5. Sep 21, 2009 at 8:41 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    When the guy mocks them up he should do this for a good install......I use 2 jack stands and a plastic crate in the center with pieces of metal plate for spacers to get the angle so there is 1" - 1-1/4" between the outer bar & door when the door is open. The inner bar should go directly under the pinch weld with about that same 1" - 1-1/4" between the pinch weld and the tube. That's how I get my angle. Any closer is too close.
  6. Sep 21, 2009 at 8:44 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks a lot. i get what your saying. but where is the pinch weld? When you say inner bar do you mean the leg?
  7. Sep 21, 2009 at 8:51 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    There are frame plates, inner and outer bar (on the sliders) , and then the legs. The pinch weld is the lip on the rocker that's spot welded together. Have him get the gap between the inner slider tube and the truck (pinch weld on body) correct, don't worry about the frame, once the sliders are sitting nicely with the body, then the frame end of the legs get cut to the right angle and length. Not the notched end (slider end)
  8. Sep 21, 2009 at 8:57 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks for the info Brian. I will let him know!
  9. Sep 21, 2009 at 9:00 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Don't let this guy mount them any closer than 1" to the body. (rocker panel) You basically want them sitting how you like them when looking at them, and make sure the doors clear them with at least that 1" I like. I've heard about people's that were mounted a 1/4" from the body and they rub and make noise...no bueno.
  10. Sep 21, 2009 at 9:01 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea I know a guy on here that had them mounted too close and he ended up cutting off some of the body at the bottom. If you lived closer to me I would have you do them for me! :(
