Slider Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TicoTRD, Aug 6, 2014.
  1. Aug 6, 2014 at 8:26 AM
    TicoTRD
    TicoTRD [OP] Well-Known Member
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    If you were to have bolt on sliders, could you use a Hi Lift on them? or would the sliders have to be weld on? thanks
  2. Aug 6, 2014 at 8:27 AM
    schwarthog
    schwarthog Well-Known Member
    Ian
    Tacoma, WA
    2014 DCSB 4x4 TRD Offroad MGM
    Ultragauge, Weathertechs, Plasti-dip rims/grille surround, Access Tonneau
    They'd probably need to be weld on.
  3. Aug 6, 2014 at 8:28 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Depends if the bolt ons bolt to the cab or frame. Mine bolted to the cab so I had them converted to weld on by a local member.
  4. Aug 6, 2014 at 8:38 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    BAMF bolt on sliders can be used with a hi lift jack. There's pictures in their bamf rock slider thread.
  5. Aug 6, 2014 at 8:40 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    A hi-lift can be used on sliders that are bolted on to the frame.
  6. Aug 6, 2014 at 11:11 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    No issues using a Hi-Lift on my Shrockworks because like others have said, they are bolted to the frame
