Slider rear door clearance
Discussion in 'Armor' started by sjtinnelly, Dec 25, 2022.
  1. Dec 25, 2022 at 3:04 AM
    sjtinnelly
    sjtinnelly [OP] Member
    2018 Tacoma TRD Off Road
    Merry Xmas guys. I just installed my 4x innovations rock sliders and everything was looking good. After all the welds cooled I noticed the rear door only has about an 1/8 of an in gap when open. I’m wondering if I should worry about or if they’ll be fine?
  2. Dec 25, 2022 at 4:40 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Well fair chance it could catch sometime under certain off camber circumstances. Is it that tight all the way along when opening?
    You could jack up or ramp one front wheel at a time to full travel and check the clearance. If it does catch not sure what you could do about it other than not open that door under those conditions.
    The frame and cab body connect via rubber body mount bushings, so there it’s flex by design. Good pictures here.
    https://www.tacomaworld.com/threads...ictures-and-a-video-too.432885/#post-12488510
    Mark77 and sjtinnelly[OP] like this.
  3. Dec 25, 2022 at 4:55 AM
    sjtinnelly
    Thanks for the response. I’m not too concerned about opening the door when I’m off camber but I guess my main concern would be slamming a rock and not being able to open the door on flat ground.
  4. Dec 25, 2022 at 5:22 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    I've been running the 4xinnovations wiy sliders for very nearly 2 years now, smacked em, dropped on em, all that good stuff. The clearance is definitely tight and I had the same concern but it hasn't been an issue at all
    sjtinnelly[OP] likes this.
  5. Dec 25, 2022 at 6:45 AM
    sjtinnelly
    Awesome thank you. Your profile pic is making me feel relieved lol
    Brownmatthall likes this.
