Sliders as Air Compressor tanks??
Discussion in 'Technical Chat' started by MESO, Aug 21, 2017.
  1. Aug 21, 2017 at 1:18 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Hey guys,
    I am putting together my on board air setup and considering using my sliders as the air storage tanks, as I don't want to mount a large tank anywhere. I am confident in the welds/sealing and tapping a air tight connection.. but what are the pros/cons of using them as tanks???
    My sliders measure 90" long, 1.75"X1.75" I.D. I have calculated this out to roughly ~1.2Gallons per slider. Combining both is almost 2.5Gal. I might run power tools VERY SELDOM though. Mostly airing up, blowing stuff off, etc.
    Thoughts? Thanks!!
    mcharfauros and sogafarm like this.
  2. Aug 21, 2017 at 1:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I've heard of others entertaining this idea, but never anyone going through with it that I'm aware of. I think that'd be pretty awesome!
    mcharfauros likes this.
  3. Aug 21, 2017 at 1:27 PM
    MESO
    State of Jefferson
    It would probably be easier and quicker than trying to mount a tank altogether. Drill, tap then screw in QD air connect right into the slider.
  4. Aug 21, 2017 at 1:28 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Only thing I'd be leery about is it handling the pressure, and the constant pressurizing and depressurizing. I'd only be leery because I've never done research on air tanks, so I'd have to see if there's some sort of special process to keep them from exploding.
  5. Aug 23, 2017 at 1:28 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just like most all pressure vessels send them out for Hydro static testing .
    You do have your certs under section IX ??If you feel confident in your welding .
    One thing about air fittings and lines on vehicles after sometime they all start to leak
    Then don`t forget a drain for each tank
    Bigmo likes this.
  6. Aug 23, 2017 at 2:08 AM
    Bigmo
    Bigmo Well-Known Member
    Brian
    Indiana
    2017 Off Road DCSB 4X4 6MT
    I don't know why it wouldn't work. Father-in-law has a 70's ford truck and rear tube bumper is a air tank. Give it a try.
  7. Aug 28, 2017 at 7:19 PM
    Chatt69chgr
    Chatt69chgr Well-Known Member
    2017 Quicksand Tacoma TRD 4X4 OFFROAD
    None
    MIght end up rusting the inside of the slider over time.
    Stig likes this.
  8. Aug 28, 2017 at 7:22 PM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    would they hold enough air(volume) to make them useful. I am no mathematician but that is where i would start before any work even starts to make sure they are useful.
    Stig likes this.
  9. Aug 28, 2017 at 7:23 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I've been using a slider as a tank for the last several years. Holds 120psi without issue
  10. Aug 28, 2017 at 7:25 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    I saw a thread on here where buddy built his own swing out for his rear bumper and he built it to hold air just like your planning on doing. ill see if I can dig up the thread haha his holds about 1gal if I remember correctly
  11. Aug 28, 2017 at 7:26 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    F'in brilliant...
  12. Aug 28, 2017 at 9:00 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Very common in Jeeps. My friend built his Jeep rear bumper into a tank as well.
    I wish I had thought about doing this when I made my sliders, and I would have built then a bit differently
  13. Aug 28, 2017 at 9:15 PM
    Boonie Buster
    Boonie Buster Well-Known Member
    PNWet
    2014 Access Cab TRD
    This is why you should install the triple nerf bar bumpers! :p
    This is definitely doable. Put a hose attachment, drain valve and Pressure relief valve, if you feel confident in your welding skills. I'm know people to utilize an entire tube buggy chassis for such a thing, and tube bumpers and such. But if the bumpers are already built, you're not going to be able to use all available space located in each tube for air capacity unless you drilled holes at each internal connection. (hopefully my rambling makes some sense)
    And on the other hand... If you have a compressor, that's decent, I wouldn't even bother trying to build air capacity into my sliders, even for the seldom use of air tools, if you want air capacity, get a longer air hose.:p :thumbsup:
  14. Aug 31, 2017 at 10:27 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    I believe Bamf did this with their bed racks years ago for a member and he said it was fine. Two birds, one stone. Do it!
  15. Aug 31, 2017 at 10:29 AM
    MESO
    State of Jefferson
    I don't really have a need to run air tools, and it will mainly be used to air up. I might just bite the bullet and go for a ARB twin compressor and be done. Keep it simple..
    Dalandser and EatSleepTacos like this.
  16. Aug 31, 2017 at 10:41 AM
    Large
    Large Red
    4xinnovations formerly known as ATO made a set, never went to production tho
  17. Aug 31, 2017 at 10:42 AM
    COVERLAND
    COVERLAND Well-Known Member
    17' Taco OR
    why doesn't anyone here carry power tanks?
  18. Aug 31, 2017 at 10:51 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    There's not really much volume inside the tubing to make a significant difference when airing up. It's a cool idea but you'll spend a bunch of time for not much gain. Even a 5 gallon tank is too small to make a big difference.
    MESO[QUOTED][OP] likes this.
  19. Aug 31, 2017 at 10:52 AM
    MESO
    State of Jefferson
    That settles that then. Thanks for the input
  20. Aug 31, 2017 at 11:21 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's what I want to do, but the diy version. Then just have a small compressor as a backup.
