Sliders hitting pinch weld
Discussion in 'Armor' started by Metallikatz3, Oct 2, 2017.
  1. Oct 2, 2017 at 7:18 AM
    Metallikatz3
    Metallikatz3 [OP] Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    So ever since my first wheeling trip late last year I was getting a "bang" just about every time the left rear wheel went over a drop off of more than about 6". I chalked it up to a bad bushing on a rear shock and kinda ignored it. Fast forward to yesterday - installed brand new shocks so that ruled out the bushing.
    I crawled around under my truck and noticed paint rubbed off from my cab hitting my sliders on one side. Interesting bit is that the passenger side has about a 3/8" gap between the pinch weld and the sliders and the drivers side was only 1/4".
    So i loosened everything up and put 2 washers between the slider and the bottom of the frame to space it down about 1/4" (gap even between both sides now). Does anyone else have a better suggestion? I've seen a few guys cut or bend the pinch weld but since I already put the spacers in I have a good enough gap now I think...
  2. Oct 2, 2017 at 10:27 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    What brand are your sliders? Some mention grinding of the pinch weld may be necessary for adequate clearance.
  3. Nov 11, 2017 at 11:20 AM
    Yota_Explorer
    Yota_Explorer Well-Known Member
    San Diego
    2015 Tacoma TRD Off-road
    I made myself a pair of sliders and welded them on. The driver side is about 1/8 closer to the pinch weld than the passenger side. I noticed the noise right away when hitting any decent size bump. If I would have known the truck flexes so much I would have put them 1/4" lower.
