Sliders vs side steps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MemphisTaco08, Apr 17, 2022.
  1. Apr 17, 2022 at 3:36 PM
    MemphisTaco08
    MemphisTaco08 [OP] Well-Known Member
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    3/1 lift 33in tires Overland Yakima system with Yakima Skyrise HD2
    Can I lift off side steps? Is there a real difference? Is clearance better (noticed bracket is bent on side steps)?
    DaleRS likes this.
  2. Apr 17, 2022 at 3:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you hit something tough off road steps will collapse.
    They may look substantial, but they aren't. Just like bull bars.
  3. Apr 17, 2022 at 4:31 PM
    TacoTuesday1
    SD CA
    Side steps are horrible.
    The only justification to run them is if you are handicapped. Which is 1% of people with them.
    the vast majority of people are not and use them to:
    -damage their truck
    -worsen the value and appearance of their truck
    -decrease off road clearance and never off road their truck
    the brackets holding them on are literally thinner than ditch light brackets which see no force applied from the ground.
    if you hit something off road, which you probably will:
    -you will waste time removing them
    -they will be trashed, turning $200 into $0 in the blink of an eye
    -it will not protect and allow your truck to slide down a rock like you want them to
    nor can you jack up on them with a hi-lift like you can a slider with the proper attachment.
    I can’t tell you what to do with your money unless I’m buying them for you.
    But sliders let you step on them just as much as a step bar if not more because they entire surface is steppable as opposed to a step bar which only has two steps per side.
    I bought a pair of RCI bolt ons for $275 used IIRC and need to touch up some rust. I bought new mounting hardware from RCI because they were missing some and it was stripped/rusty.
    I heard sliders can rattle if you install them close to the frame.
    but with the logic of wanting close frame support and RCI install instructions stating to mount them close, I pushed them close with jacks before final tightening the bolts.
    I went bolt on because I want them removable if there is ever any work that needs to be done such as damage, replace, paint
    And bolt on seems to spread the load better than a couple of tubes welded to the frame.
    It’s a weak c channel frame. Last thing I need is load in a narrow spot tweaking the frame
    it’s understandable why many don’t get sliders when you see new ones for $1000 and used for $998
    but most people never admit that’s the reason they fucked up their truck with step bars
    Sliders also look badass. They can angle upward for clearance. They can kick out at the rear to pivot around trees and protect the back side of the truck. Their design can match the truck and bumpers.
    step bars mount into tiny threaded body holes from the factory.
    If you hit them with a rock it can bend them into the body of your truck, damaging it.
    It can also rip the threads out of the holes.
    my buddy with step bars said he won’t go sliders because he doesn’t off road often or hard enough to justify it. When there’s an obstacle on a trail he turns back or goes around. Another valid reason to not get them
    Sliders can protect from door dings, shopping carts, and side impact collisions.
    Westscott designs had a 4Runner with sliders that damn near got Tboned at 45mph and looked fine.
    sliders also give you confidence and mental peace while driving on regular roads.
    Whenever somebody fails to observe the rules of the road and tries to crash into you in a way that insurance will find them at fault, or doesn’t want to let you merge - with armor, you just smile
    its kind of like driving a semi truck. If semi truck drivers do their job properly (slow in right non passing lane, signaling, etc) then they have nothing to worry about someone in a car tries merging into their trailer.
    except for some reason people are willing to put up more of a fight against a Tacoma, even if it’s a heavy armored truck with thick steel that their car does not have. but usually eventually they get close enough to see the steel and realize it would not be good to rear end, not a fight they’re gonna win, etc
    I used to drive a slow old car. I’d get paranoid about being rear ended and watch in the mirrors to merge.
    Now I drive a slow old Tacoma. I still look in the mirrors. People still get on my ass mad expecting it to have Ferrari 0-60, and flabbergasted that as a manual it pauses for a second when shifting gears
    but with armor, you don’t care.
    They can go ahead and crash into me. Have their insurance pay me $1400. Buy a $3 black appliance epoxy from Home Depot to touch up the scratch and move on.
    they say in a parking lot if you can, move into the center and go slow to avoid impacts with people backing out.
    But there’s always gonna be that one person who crashed their car, now in an insurance rental, who is gonna slam that insurance rental into reverse with a blindfold on and hit the gas.
    And people with a nice new car equipped with a backup camera that don’t look at the screen
    Sliders protect the body from that
    Actual body repair is hard, expensive, and time consuming
    step bars are often weak thin lightweight flimsy aluminum barely strong enough to support the weight of an average person standing on them. They can’t be lifted off of
    if you get hit in the rear, cool. Turn it into an upgrade. Buy a steel bumper.
    If you get hit in the side there’s no way to flip that into something positive/upgrade as opposed to simply diminishing the value of the truck by repairing it to original condition but now with a collision on its records
    only one con I can think of. I don’t know how much weight a slider adds in terms of making 0-60 and mpg worse
    They are heavy to pick up by hand FWIW, more than a step bar
    If you get used step bars cheap you can always sell them later provided you don’t ruin them on a trail
  4. Apr 17, 2022 at 6:28 PM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    Thanks for thorough info. Step bars came with truck but noticed a bracket was bent, probably by me offroading which got me wondering about sliders.
    Any suggestions on best bang for buck bolt ons?
    DaleRS likes this.
  5. Apr 17, 2022 at 6:35 PM
    DaleRS
    DaleRS Well-Known Member
    Dale
    Cleveland, Ohio
    2015 Black DCSB SR5 w/ Snugtop
    The only reason I ever installed step bars was that I have family members with prosthetic legs and it drove me nuts hearing those things bounce off my rocker panels and leave scratches and dents.
    I vote sliders, they look mean and I wish I could get a set but I just don't see the reason for someone like me to ever have them!
    If you do decide on step bars, Facebook marketplace is the way. I got brand new third-gen takeoffs for $80.
    MemphisTaco08[OP] likes this.
  6. Apr 17, 2022 at 6:42 PM
    TacoTuesday1
    SD CA
    I went with RCI because the set was like $275 used
    And have since gone with them for more other stuff like a skid plate given it seems competitively priced and decent quality
    on that note, sure there is another brand of gas tank skid with a different method of mounting.
    And sure a stronger skid is heavier because they’re gusseted, which is rare. My RCI gas tank skid is not gusseted but if I ever bend a skid and the need arise, I can always bend it back straight and weld on gussets later.
    WarFab might release gusseted skids - they also do serious wheeling.
    For sliders I’d say find a brand you like, and look at the part.
    Look to see if it offers what you want. Like whether you want tubular, or fill plate to keep tree branches out and have more of a stepping surface.
    DOM material may be preferred over HREW and others
    See if you want a kickout, and what degree up angle. Some have a rounded kickout, some don’t. Some are flat while others are 20deg up
    look at the mounting system. The more coverage it has the better and stronger it is.
    If the attachment plate looks small and weak the probably avoid it.
    you may already have a preference for certain brands if you have other stuff from them and good experiences.
    me for example I have good experiences with ATH, WarFab, and RCI; so I probably prefer them. But quality is quality no matter who makes it.
    my experience with another brand I won’t name is hearing their leafs suck and that their bumpers are ugly so I never consider them for anything, for example
    Sometimes when you want a part it’s a matter of making the list of all 8 companies that sell it and then crossing one by one off the list for valid reasons until there is only one good part remaining
    Looking at the pictures back to back and removing from the choices which one is ugly
    there is less to choose from given companies like Pelfreybilt and Mobtown have shut down
    shipping cost and if they’re local to you might make a difference. Sales.
    Plus if you go bolt on they can be resold for whatever reason later
  7. Apr 17, 2022 at 7:13 PM
    scoomas
    scoomas Well-Known Member
    Scott
    2006 Silver Tacoma TRD/OR
    The trail gear sliders are actually really well built and are maybe $450. They’re super simple and fit well. Sliders kind of suck as “steps” with the exception of climbing into the bed but they will do their job protecting a pretty expensive panel
  8. Apr 29, 2022 at 3:36 AM
    Kuzumonkey
    Kuzumonkey Active Member
    2020 TRD Off Road 3 Pedal
    I just bought some Body Armor 4x4 Revo step sliders and am pretty happy with them. Inexpensive as sliders go and available on Amazon with free shipping so no crazy wait time. They bolted on cleanly and while they may not be the strongest slider, they are supposed to be made from DOM tubing that you can use to jack up the truck. I think they're a good balance of price, weight, and strength if you aren't into serious off road use. I feel confident they could take a hit, just don't know how many.
  9. Apr 29, 2022 at 3:42 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Hi, I’m one of the non-disabled idiots @TacoTuesday1 mentioned who owns steps (nerf bars). For me they are incredibly functional, and even more so for my wife and kids. The honest truth is the truck looks better without them, but I’m old enough to have higher priorities than that.
    When I off road I take them off. I don’t do the type of wheeling that requires sliders.
    Musubi3 likes this.
  10. Apr 29, 2022 at 4:13 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    As long as you don't expect one to perform like the other you're good. Side steps have their place and are very useful as long as you aren't trying to land the truck on them.
    I got some C4 sliders with step treads and they offer great protection, but take some getting used to as side steps since the tread is close to level with the cab floor.
  11. Apr 29, 2022 at 4:21 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Have you ever needed to lift off the side or have you ever scraped the side steps or even come close?
    If no and no just enjoy your truck and have fun man. Peeps here sometimes like to prep for KOH and don’t have a single scratch on all their armor. If you’ve never come close to scraping, you good! Have fun! :)
    BattleKat likes this.
  12. Apr 29, 2022 at 4:26 AM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    I kept my eye out on the forums and scored some demello sliders for $150
  13. Apr 29, 2022 at 4:28 AM
    Chris2009
    Chris2009 Well-Known Member
    Massachusetts
    2013 Reg Cab 4x4
    I picked up some OEM side steps mostly to keep the truck from getting obliterated by door dings while parking in tight city lots. As a bonus they do make it easier for the kid to get in and I feel they improve the look of the regular cab. Slightly less weenie-ish.
  14. Apr 29, 2022 at 9:09 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I rocked steps for a few years. hit a rock wheeling and bent the whole step. Upgraded to sliders shortly after
    Marc70 likes this.
  15. Apr 29, 2022 at 7:38 PM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    Gr8rSherman8r likes this.
  16. Apr 29, 2022 at 11:00 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    Mine came with side-steps, and I find them real handy for tying down my kayak.
    After redoing my suspension, I'll be swapping them for sliders.
  17. Apr 29, 2022 at 11:04 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    Bull bars are for deterring cattle.
    If they're on a train
    With a million pounds of potential energy behind them.
  18. Apr 30, 2022 at 12:46 AM
    Gr8rSherman8r
    Gr8rSherman8r OKLA•YOTA
    Owasso
    2015 MGM TRD Sport Longbed
    Done by me: decals, plastidip, and vinyl. More to come. Not done by me: Icon front/rear suspension; Total Chaos UCA’s; Method wheels/34” Falken tires; Prinsu cab rack/LED light bar; V1Air compressor piped to a 2.5 gallon underbed tank; Pelfreybilt front/rear bumpers; Smittybilt front winch.
  19. May 7, 2022 at 8:51 AM
    Barrydd
    Barrydd Well-Known Member
    2021 TRD Off Road DCLB Barcelona Red
    Do you have any pictures of these installed?
    Thanks...
  20. May 7, 2022 at 9:32 AM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    I have BAMF bolt on sliders and can lift the entire side of the truck with one Hi-Lift jack. I've also bounced them off a tree or two and other than fixing the scraped off paint, there's never been any damage to them or the truck.
    Hardest part of install was drilling holes in the frame. Many of the holes you have to drill upside down and it's not easy keeping the bit lubed. I dulled two bits before I was done. (Drill Dr. to the rescue!)
