Sliders!
Discussion in 'Garage / Workshop' started by crumf20, Apr 12, 2014.
  1. Apr 12, 2014 at 7:44 PM
    crumf20
    crumf20 [OP] Well-Known Member Vendor
    Wesley
    Tempe, AZ
    2000 Tacoma 3.4L 4x4
    33 x 12.5 x 15 Cooper Discover STT Pro's, All new UCA's LCA's including all balljoints, Bilstein 5100's all around with Dakar leafs w/ AAL in rear with 1inch extension Shackles, Eibach coils up front with 5100's set at 1.75 and 1/2inch spacer as well. Kenwood Double din deck with JBL 12in Sub: 300rms. Rockford Fosgate speakers front and back. New OEM black grill, Black Anzo Headlights with ddm tuning 6000k HID's. Seat Covers Unlimited black and grey 2 tone seat covers. Cobra CB Radio and PA system.
    Anyone got any specs and dimensions for 2nd gen DCSB sliders!? Looking to weld up my own this summer and seeing if I can base mine off of anyones?
    :D
  2. Apr 12, 2014 at 8:52 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Probably gonna need to be bout 80" long. Just get out a tape measure and a piece of paper and get a design down. Really not that hard. Pretty basic and simple. If you have never fabbed anything before then I'd recommend square/rectangle tube just for ease of fab work and joint alignment.
  3. May 3, 2014 at 10:45 AM
    Tonka
    Tonka Pro-Darwinism
    Taylor
    America's Basement
    14 DCSB prerunner 04 AC 4x4 TRD OR. '16 DCSB 4x4 TRD OR
    '04 265/70R16 Dueler A/T, Softopper, Bilstein 5100's, Toytec AAL, DIY Satoshi, Midland CB, ARB front. Self fabb'd rear bumper. Smittybilt X20 winch '16 custom car grill, Cooper ST Maxx
    I just got done fabbing my own sliders. I used 4- 10ft sections of 1" galvanized water pipe ($20 ea) a MIG and a pipe bender. they turned out great. What I did was find a style I liked (ALL-Pro) and fabricated brackets (which was the most difficult part). once you get the brackets built and installed (takes a lot of walking back and forth to the welder/grinder). I measured my base bar length. (i eyeballed it and liked it at 83") welded it up. then i built the step bar and i wanted the 'flare-out' so i did some trial and error bends on a piece of the scrap pipe. matched both sides. welded then. painted them installed them... loved'em!! :mudding::woot:
  4. May 3, 2014 at 10:47 AM
    Tonka
    Tonka Pro-Darwinism
    Taylor
    America's Basement
    oh yeah with materials and consumables and buying lunch for my buddy helping me out they coat ~$150
  5. May 4, 2014 at 4:16 PM
    crumf20
    Wesley
    Tempe, AZ
    AWESOME MAN! Just the response I was looking for!! Post some pics??
  6. May 8, 2014 at 11:22 PM
    Tonka
    Tonka Pro-Darwinism
    Taylor
    America's Basement
    first picture is the base bar, welded to the three body mounts i built utilizing the OE step bar mount holes. (I decided to go there instead of the frame because I couldnt bring myself to weld/drill anything to my brand new truck frame)
    Second picture is the outer frame of the bar. (trial and error!)
    Third Picture is the almost completed rock slides complete with support gussets
    Fourth picture is self explanatory, i rattle canned them with spray truck bed liner
  7. May 8, 2014 at 11:34 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    LOOKS good, but I hope you don't plan to actually use those!
    pretty sure those mounts would crumble under any load and that pipe would not take very much abuse other than parking lot door dings..
    OP, DCSB are usually 80" along with ECSB both 1st and 2nd gen but length/design is totally upto you.
    Id recommend 1.5" .120 wall tubing (not pipe) at minimum and 3/16 minimum mounting plates and gussets! Most use 1.75" .120 wall tubing for the outer rails and hybrids are generally 2x2 square .120 wall tubing..
    Depending on where you shop at for your materials and what quality of material you use it will run you around $150-$250
    There are lots of pics and ideas floating around, You can follow the link in my sig as well and get some ideas if need be!
    Good luck and post lots of pics!
    If you go the hybrid route youll use approximately 18.2' of square tubing and 15.9' of round tubing... Then whatever size you decide to make your frame mounting plates and gussets... so 1 stick of each material should be good or if you go all round tubing then 2 round sticks would be plenty... Those measurements are guestimates and do not include a kickout
  8. May 8, 2014 at 11:41 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Looks good
    Never jack on them or use them as sliders the OEM mounting points will mangle the bottom of the cab
  9. May 9, 2014 at 6:43 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    That's a good looking product, but I am with everyone else, those are going to crumble under any load.
  10. May 9, 2014 at 8:16 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    What
    The
    Fuck
    There's a reason sliders are mounted to the frame and not the cab. The cab sheet metal will hold a couple hundred pounds. Congrats on making nerf bars...not sliders.
  11. May 9, 2014 at 9:32 AM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    You realize that welding galvanized steel releases toxic gasses?
  12. May 9, 2014 at 9:36 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    this was my next WTF...
    here comes lung cancer
  13. May 9, 2014 at 9:40 AM
    Redneck92
    Concord, NC
    More like death, shit is deadly toxic in gaseous form.
  14. May 11, 2014 at 10:53 PM
    Tonka
    Tonka Pro-Darwinism
    Taylor
    America's Basement
    #1 I failed to mention that I used 1/4" steel plate with gussets to mount it...
    #2 Galvanized pipe is extremely toxic. However grinding the zinc coating 2-3" away from the weld point and welding outside will make the process nearly harmless
    #3 they do look great! thank you!
  15. May 11, 2014 at 10:54 PM
    OZ-T
    Peter North
    British Columbia
    Mount it to the bottom of the cab at the factory mount locations or to the frame ?
  16. May 12, 2014 at 8:42 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    1/4" steel plate doesn't wont' help when it's bolted up to sheet metal.
  17. May 12, 2014 at 11:14 AM
    Tonka
    Tonka Pro-Darwinism
    Taylor
    America's Basement
    we have already established that :rolleyes:
  18. May 12, 2014 at 11:15 PM
    Tonka
    Tonka Pro-Darwinism
    Taylor
    America's Basement
    to the OP I stated that I used Galvanized water pipe, If you go to Lowe's they carry Southland Pipe & Company piping rating ASTM A-53 sold as generic GAL water pipe. "ASTM A53 is a carbon steel alloy, used for structural steel pipe. The alloy specifications are set by ASTM International, in specification ASTM A53/A53M. A53 pipe is suitable for structural or pressure applications".... I've done the homework.... However like I posted I did mount them to the cab mounts. I live in Florida not the MOAB they will do everything I need them to do and more. I butted the baset pipe to the stock lift point. Im so certain they will hold the truck up that I have Hi-Lifted the truck via the pipe... Is the frame a better spot? yes... but it will suffice for my needs! best of luck to you!
  19. May 12, 2014 at 11:18 PM
    OZ-T
    Peter North
    British Columbia
    I wanna see pics of the truck lifted on those things
  20. May 13, 2014 at 8:55 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Florida or not you do not have sliders on your truck the cab is not designed to support the truck not sure why you think you have a lift point on your cab you don't. The first thing you hit with those they are going to cave in 1" pipe will never hold up as sliders even if they were welded to the frame.
