Sliding Cargo Divider
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smolenski7, Oct 7, 2009.
  1. Oct 7, 2009 at 2:49 PM
    Smolenski7
    Smolenski7 [OP] New Member
    I just installed the Toyota Cargo Divider. It's a big PITA to slide along the rails because the bolts that attach the divider to the rail keep getting caught in the slots along the bottom of the rail. Does anyone else have this problem? If so, how can it be solved?
  2. Oct 7, 2009 at 4:11 PM
    gavonder
    gavonder She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    Yeah, it is a pain. I loosen all 4 of the knobs before moving it. That helps. I recently saw that someone on here installed the brackets upside down, so that the divider goes in from the top. I think that might help. I'm going to do that this weekend and see if it helps.
    GA
  3. Oct 7, 2009 at 4:29 PM
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    They are nice. I had one.
    Yes, I had the problem.
    My solution:
    http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=96811
    Actually I thought the slots along the bottom were designed for fixed position indents (more secure position?). Or drain holes? The real solution would be a solid bottom channel, if you can find one.
    Good luck!
  4. Oct 7, 2009 at 5:05 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I flipped my brackets upside as well, makes it alot easier to remove. But yea as far as sliding it back and forth, is a little tough but I don't mine too much so it doesn't bother me. And with having the brackets upside down it's almost easier just to pull the divider out and move the brackets separately.
  5. Oct 8, 2009 at 3:39 AM
    KodiakVA
    KodiakVA Well-Known Member
    Richmond Virginia
    09 4x4 XCab Sport BarcelRed
    Same problem here. I have been making sure I have my finger covering those drain slots when I slide it. I do one side then the other to inch past the hole.
    I like the flip it over idea and I may try that.
  6. Oct 8, 2009 at 11:20 AM
    Smolenski7
    Is it possible to flip the track over so the holes are on the top?
  7. Oct 8, 2009 at 4:42 PM
    Smolenski7
    Just looked at the track, the top is the same as the bottom.
  8. Oct 8, 2009 at 5:45 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    I stuck a dab of paraffin wax to the bolt heads and slid them up and down the track a few times by hand. Now the gate moves smooth as silk and if the bolt head ever does rotate around (pretty rare) it never gets stuck, just slips out of the hole in the rail.
  9. Oct 8, 2009 at 5:58 PM
    CVEIN
    CVEIN Member
    SOUTH FLORIDA
    2010 TACOMA TRD SPORT
    How much did that run you in price?
    I was looking at the roll n lock cargo system...any thoughts?
