Sliding nuts for roof rack tracks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonykarter, Mar 15, 2023.
  1. Mar 15, 2023 at 12:38 PM
    tonykarter
    tonykarter [OP] Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Thanks for investing your valuable time in my post. I have a need to attach my shower enclosure to a Front Runner rack with SLIDING nuts so that I can loosen the bolts attaching it to the rack. I want to be able to slide the shower out from the side of the truck about a foot, then tighten the bolts/sliding nuts down again while in use. Slide the whole thing back "in" and retighten for travel. I contacted FR and they couldn't help. My question: Have any of you needed sliding nuts for your build, and if so, which ones work best with FR's mounting grooves? Yes, I have tried doing it with M8 half-nuts. I've also tried using M8 bolts with thin heads. Both of which "hang" when you try to slide them. As there are four that need to slide, and all four must cooperate together if it is to work, and they hang up and won't slide. Hence my need for slide nuts. Thanks guys!
  2. Mar 15, 2023 at 12:51 PM
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    Thought about putting a Fridge Slide on the roof rack with Shower/Awning brackets?
    What do you have the awning/shower mounted to currently? Awning mounts or some custom brackets?
  3. Mar 15, 2023 at 12:55 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    The Title of this thread is Misleading...
    ktbell444 likes this.
  4. Mar 15, 2023 at 2:49 PM
    Hudock08
    Hudock08 Active Member
    2021 Cement Tacoma TRD Sport
    Fox 2.5 Factory Race Series w/ Remote Reservoirs - F&R BF Goodrich 285/70/17 T/A KO2s on 4Runner TRD Pro Wheels - Alu-Cab Contour Canopy
  5. Mar 16, 2023 at 5:51 AM
    tonykarter
    Snuff Gully, Texas
    I'll try filing those edges. Unfiled it binds up every time. Still, if slider nuts exist I'd rather use them. More bearing surface than the filed bolt.
