Sliding out of gear!!??
Discussion in '1st Gen. Tacomas (1995-2004)' started by T-Sali12, Mar 2, 2010.
  1. Mar 2, 2010 at 1:30 AM
    T-Sali12
    T-Sali12 [OP] Member
    98 2.4L Standard Cab
    Fabtech 3.5" performance lift, 3" body lift, full magnaflow exhaust, K&N cold air intake, cobra PA, pioneer head unit ans speakers, 2 bazooka 10'' subs with 400w amp
    I have a 98 taco, 2.4l manual, with almost 100k on it, for some reason it slides out of 1st,3rd, and sometimes 5th gear. Its really bad when the car is cold for some reason it wont stay in first or third at all 5th usually isn't bad but every once in awhile it falls out. I do have a 3in. body lift along with my suspension lift, but i dont think that is really affecting it. Anyone else have this problem, any input would be appreciated.
    Thanks,
    Taylor
  2. Mar 2, 2010 at 2:35 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Is it hard to put in gear ? Does it "grind the gears" when you try to go from one gear to another? Sounds like maybe a Synchromesh issue, need a little more info if possible.....:cool:
  3. Mar 2, 2010 at 12:36 PM
    T-Sali12
    No problem putting it in gear it just wont stay in gear for some reason... No grinding... I feels like something is stopping those gears from completely locking in but i have taken off the shifter cover and it seems that the body lift is not affecting it so i am not sure what the problem is.
  4. Mar 2, 2010 at 3:50 PM
    scocar
    scocar Patron of the Farts
    This sounds similar to a typical issue with the older pickup (pre-Tacoma) I had:
    On my old 93, there was a urethane or rubber ball at the base of the stickshift that disintegrates after about 100k miles. It screws up the fulcrum angle on the stick, and when you shiftm the stick just mushes back rather than properly engaging the gear. Mine would just "fall out" of 3rd gear. I don't know if this is the same for your truck, but if so, this is about a $14 part and an easy 1/2 hour job from inside the cab. I know ther must be writeups for it, maybe on Yotatech.
    I just bought a used 2001 Tacoma, so i am new to the truck, but my guess is that they are the same or similar up until 2nd gen.
  5. Mar 2, 2010 at 5:06 PM
    saltshaker
    saltshaker Well-Known Member
    johnny
    north carolina
    2011 TRD Off Road MGM AC
    AFE CAI, Fold-a-cover
    my '01 started doing that about two years ago, it did it almost every time I went through the gears for a few days, but it got better and better over the next few months.
    It probably happened only once or twice last year. I'm all stock by the way.
  6. Mar 2, 2010 at 5:09 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    shifter ball bushing.. or bad synchros.
  7. Mar 2, 2010 at 5:14 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    mine does that with 4wd on bumpy roads occasionally :/
    stick lever ftw though
  8. Mar 2, 2010 at 8:11 PM
    T-Sali12
    Thanks this sounds right ill definitely give it a try... thanks for everyones input ill let you know how it goes
