Sliding seat not working in ext. cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco Addiction, Feb 1, 2017.
  1. Feb 1, 2017 at 4:11 AM
    Taco Addiction
    Taco Addiction [OP] We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Hey Gang,
    My sliding seat in my 04 is not working, was when I bought it some months ago. The rear foot lever and hand lever work great but no longer slides forward simultaneously.
    Is there a spring that has slipped off perhaps?
    I use this feature daily as my kids love going to school in Dads truck vs. Moms SUV...dont blame em.
    Thanks for the help
  2. Feb 1, 2017 at 8:32 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Subb'ed - I've been trying to solve this very same problem on my 98
  3. Feb 1, 2017 at 8:48 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Went to go look at how it works and basically the way it works is that once the seatback goes down to a certain point it pulls a cable which pulls the lock back from the bar with the slots in it which in turn releases the seat and it comes forward (assuming the large spring is also in tact). Kinda hard to explain.. So check this cable here to see if its broken or loose or disconnected. You may also need to just adjust it
    Seat up ^
    seat down ^
    **I can also get more pics if needed
    pray4surf and harper7 like this.
  4. Feb 1, 2017 at 9:39 AM
    Taco Addiction
    Houston, TX
    Thanks Jim. That looks like the cable alright. Mine appears to be fine but I bet the problem is upstream at the foot pedal/wire connector (inside the damn seat). Poked and prodded a bit but pretty sure the issue is within the innards of the seat on the outboard side. If I have time Ill tinker more.
    Thanks much Jim
    CC
