Sliding sensation sometimes right before complete stop.
Discussion in 'Technical Chat' started by ninernation, Jul 3, 2022.
  1. Jul 3, 2022 at 12:09 PM
    ninernation
    ninernation [OP] Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    I have an occasional sliding sensation when bringing the truck to a complete stop. It feels somewhat like the brakes briefly let off, but that the body continues moving forward and then rebounds back, except I don’t have the sensation that the wheels are rolling forward as , just the body. This doesn’t always happen. I just completed a 2500 mile road trip and the truck performed just fine, including thru many switched backed mountain passes. I’ve checked my suspension hardware and everything I’ve checked is at torque specs.
    Anything I should be considering?
  2. Jul 3, 2022 at 12:21 PM
    EarthCruzn
    EarthCruzn Well-Known Member
    Florida
    2022 TRD V6 4WD Manual 6 Speed
    DCSB SPORT
    Maybe you need to have the brakes inspected, could be the rear shoes have dust build up and are slipping a bit.
    wi_taco and ninernation[OP] like this.
  3. Jul 3, 2022 at 12:47 PM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    are you "dog tracking"? where the back sits a bit to the side compared to the front (bad alignment), this will certainly cause a kick to the side under heavy braking.
    You may also have a sticking caliper...could try cleaning/greasing the slide pins
  4. Jul 3, 2022 at 12:47 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Loose or broken body mounts?
    wi_taco and Bivouac like this.
  5. Jul 3, 2022 at 12:56 PM
    Bishop84
    Bishop84 Well-Known Member
    This is my first thought, similar to braking with a body lift. Feels like ass.
  6. Jul 3, 2022 at 1:53 PM
    ninernation
    WA
    TRDOR
    OME, ALUCAB, RCI
    No. it’s a quick and brief forward then rebound sensation.
  7. Jul 3, 2022 at 1:54 PM
    ninernation
    WA
    TRDOR
    OME, ALUCAB, RCI
    from what I can tell, they look fine.
  8. Jul 4, 2022 at 8:10 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What happens in reverse?
    If what your stating is correct something is moving and then being pulled back into position.
    You have ruled out the seat being loose or the floor being cracked?
    Bed mounts bushings intact and hardware tight?
    Bad bushings in your leaf springs or control arms?
  9. Jul 5, 2022 at 4:41 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Could be axle wrap
    Done anything to your rear suspension?
  10. Jul 5, 2022 at 5:38 PM
    ninernation
    WA
    TRDOR
    OME, ALUCAB, RCI
    dakars and ome shocks but those have been on for 30k miles
