Slight Click on first turn from park..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Drumtech, Feb 3, 2021.
  1. Feb 3, 2021 at 8:13 AM
    Drumtech
    Drumtech [OP] Member
    Sean
    2021 Tacoma offroad
    Brand new 2021 off-road noticed a slight click/noise when I make first turn from park then goes away. Almost sounds like the noise when traction control engages but so slight it’s like a piece of paper is just catching on the steering wheel like a ripped off tag that’s stuck in there. Kinda hard to explain but wondering if this is normal. Thanks
  2. Feb 3, 2021 at 8:39 AM
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    Doesn't sound all that normal. 4WD isn't on is it?
  3. Feb 3, 2021 at 8:43 AM
    Drumtech
    Sean
    2021 Tacoma offroad
    Nope I spent a lot of time learning how to use 4wd since this is my first. I keep it off almost all the time except when we got 27” of snow here recently but this started before the snow . Iam highly frustrated at something g so possibly minor. I had a little issue with my Nissan when it was new going over bumps and found out that was normal and Kinda delt with it
  4. Feb 3, 2021 at 9:24 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    I wonder if it's the steering wheel lock.
  5. Feb 3, 2021 at 10:03 AM
    Drumtech
    Sean
    2021 Tacoma offroad
    I will get it to the dealer soon hopefully they can recreate the problem or hear it (they should cuz I hear it every time the first turn only)..it’s so minor it could be Normal idk but like first reply doesn’t sound normal. It’s exhausting I have to deal with this working 6 days per week (63 hours) and my only day off they are closed
  6. Feb 3, 2021 at 10:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    What does that mean?
  7. Feb 3, 2021 at 10:27 AM
    Drumtech
    Sean
    2021 Tacoma offroad
    It only clicks on the first turn when parked for a period of time. every other turn on my drive it does not click. It’s kinda hard to explain the sound whether is a click or what but it’s only on the first turn. Most of the time it’s a left turn I haven’t noticed if it’s right also cuz from work I always turn left. It’s such a slight noise it almost seems normal. But am concerned cuz it should be flawless for such an expensive vehicle
  8. Feb 3, 2021 at 10:39 AM
    Fett85
    Fett85 Well-Known Member
    Ohio
    2021 Tacoma TRD Off Road 4x4
    Are you in a colder region where ice breaking apart is possible?
  9. Feb 3, 2021 at 10:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Is it inside the cab or outside?
  10. Feb 3, 2021 at 10:42 AM
    angerbot
    angerbot Well-Known Member
    I know the sound you're referring to OP, it's normal. Mine has done it since new and my 4Runner did the same before that, don't worry about it.
    AmateurTaco1313 and Drumtech[OP] like this.
  11. Feb 3, 2021 at 10:42 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Sounds like it could be brake pad/pads sticks to rotor and breaks loose, aka pad shift.
    DWD484 likes this.
  12. Feb 3, 2021 at 11:05 AM
    Drumtech
    Sean
    2021 Tacoma offroad
    Sounds like inside cab. almost like something rubbing slightly between steering wheel and what it mounts to
  13. Feb 3, 2021 at 11:06 AM
    Drumtech
    Sean
    2021 Tacoma offroad
    Hopefully glad to hear something like that. Iam not the only one with the problem. Did u have yours looked at?
  14. Feb 3, 2021 at 11:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is not fun to get in there, but if you look where your steering shaft goes through the cab floor above your brake pedal, there is a plastic collar over it. With some pain and contortions, you can remove the plastic nuts and wiggle it out. There might be something behind it making the noise?
  15. Feb 3, 2021 at 11:28 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Mine does this. It's not a problem. I'm curious what it is but haven't cared to look into it. I feel like it might be steering wheel lock related. This has been posted before with no resolution I believe.
    Drumtech[OP] likes this.
  16. Feb 3, 2021 at 4:03 PM
    angerbot
    No, it's never caused a problem. I think it's steering wheel lock or something, and totally normal.
  17. Feb 3, 2021 at 4:07 PM
    moejartucci
    moejartucci New Member
    21 TRD Pro - Lunar Rock
    I noticed the same on my 21. The dealer told me its likely the steering wheel lock fully disengaging.
  18. Feb 3, 2021 at 4:32 PM
    mrengineerical
    mrengineerical Well-Known Member
    Baltimore, MD
    2019 Tacoma TRD Sport DCSB
    It's the ABS self check. Makes a "clunk" sound on the passenger front side. It happens when you put the vehicle from park into drive and go about 3-5 mph or so.
    1Crusader likes this.
  19. Aug 17, 2021 at 8:36 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    Ever figure out what this is? My SR5 never did it but my new 21 does it every time I pull out of the driveway
