Slight grinding noise when turning sharp, I cannot figure out what it is.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by upchurchr, Jul 28, 2023.
  1. Jul 28, 2023 at 5:42 PM
    upchurchr
    upchurchr [OP] Member
    2020 Tacoma TRD
    Hi I have a 2020 Tacoma TRD off road. It has 55k in miles. I bought it used, so I’m unsure of history. When I turn real sharp it makes like a soft grinding noise. It sounds similar to if you took to plastic water bottles and ran the lids against each other. I’ve topped off power steering fluid, and am unsure of where to go to next. Does any one have any ideas?
  2. Jul 28, 2023 at 5:45 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Stock set up ? Need some more info .
  3. Jul 28, 2023 at 5:51 PM
    upchurchr
    2020 Tacoma TRD
    Yes sir, absolute stock as far as I know. I bought used, and I think it was used as a rental previously.
  4. Jul 28, 2023 at 6:03 PM
    Mallcrawler20
    Possible bad coil springs struts or shocks. I would start there check those . I would also check steering rack and tie rods .
  5. Jul 28, 2023 at 6:04 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Do you have any video or audio? Have you looked underneath to see any wear or just put the wheel hard over while parked to see if anything is hitting anything else?
  6. Jul 28, 2023 at 6:09 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Sounds like a Toyota to me?
  7. Jul 28, 2023 at 6:26 PM
    upchurchr
    2020 Tacoma TRD
    I will get someone to check those things, as I don’t want to look for. Thanks for your reply. also no audio, video, etc. I’ve tried to replicate it while not driving and wasn’t able to.
    Also if that’s just a Toyota noise, perfectly fine with me. Just wanted to check. This is my first Tacoma.
  8. Jul 28, 2023 at 6:28 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Drove 3 foreign vehicles into high miles.
    1st front end part to go on all 3 was the cv axle. with it's popping and clicking when turning.
    Will get worse over a short period.
    Usually can tell by a torn boot.
  9. Jul 28, 2023 at 6:34 PM
    upchurchr
    2020 Tacoma TRD
    Is it hard to replace a cv axle? I work in the medical field, and am not very mechanically inclined.
  10. Jul 28, 2023 at 6:38 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    On a newer vehicle it certainly helps that bolts aren't all rusted on.
    I'm not going to pretend it's delightfully simple.
    A bunch of other stuff needs to come off and they can be a pain popping them out.
  11. Jul 28, 2023 at 6:44 PM
    RedWings44
    Michigan
    Have you taken it in to be looked at? It may still be under warranty depending on what it is. And no, I don't believe it's a "Toyota noise."
    BlackTRD4Me likes this.
  12. Jul 28, 2023 at 6:49 PM
    upchurchr
    2020 Tacoma TRD
    I have not had it looked at, I assumed the warranty would have already expired. But I haven’t checked to see if it has.
  13. Jul 28, 2023 at 6:50 PM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    Ok so I'm having a hard time with this part.
    Is this something people really do?
    Are these regular 16.9oz water bottles?
    Are the bottles full or empty?
    Do you keep the lids on the bottles while doing this?
    I am actually kinda serious lol.
    BlackTRD4Me, tcjacado and bkhlrTaco's like this.
  14. Jul 28, 2023 at 6:53 PM
    upchurchr
    2020 Tacoma TRD
    It’s the only thing I could find to mildly reflect the noise. But the bottles were regular 16.9 oz bottles and full. But glad to satisfy the curiosity, I also like to know the details.
    bkhlrTaco's likes this.
  15. Jul 28, 2023 at 6:59 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    If it is a torn boot/bad joint, some miles can be saved by packing the joint full of grease and repairing the boot, or reattaching it if it just came off.
    If it's clicking real bad there's not much hope in saving it.
  16. Jul 28, 2023 at 7:14 PM
    upchurchr
    2020 Tacoma TRD
    I’m hoping it will be okay for a while. It’s not terrible right now. Just an occasional thing when I turn real sharp.
  17. Jul 28, 2023 at 8:27 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Where does the sound come from? I mean does it sound like it’s coming out of the steering column or the instrument panel? Or is it outside the cab?
  18. Jul 28, 2023 at 8:40 PM
    upchurchr
    2020 Tacoma TRD
    It does sound like it’s in the cab like maybe from the steering column.
  19. Jul 28, 2023 at 8:51 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Normal mysterious Toyota noise. I don’t know what it is, nor how to replicate it consistently. Almost sounds like relays chattering on and off?
  20. Jul 29, 2023 at 6:40 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Don’t make sharp turns.. problem solved or delayed…. Seriously you should have it looked at by a good mechanic.
