Slight lean to the left
Discussion in 'Suspension' started by BLK2012, Mar 5, 2013.
  1. Mar 5, 2013 at 6:19 PM
    BLK2012
    BLK2012 [OP] Active Member
    Joe
    AZ
    Recently lifted 2012. At the gas station tonight I noticed it looked like the drivers side rear was leaning down a little bit. I came home and took out the tape measure. Sure enough its about 1/2" to 1" lower from the center of the hub to the bottom of the fender. Why?
  2. Mar 5, 2013 at 6:20 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Columbia, SC
    2015 DCSB 4x4 trd offroad
    Ome 885, dakars, lr uca, bed bars sos sliders
    what lift/suspension do you have?
  3. Mar 5, 2013 at 6:22 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    taco lean
  4. Mar 5, 2013 at 6:22 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This ^^
  5. Mar 5, 2013 at 6:24 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Isn't the taco lean in the front? He's leaning in the rear.
  6. Mar 5, 2013 at 6:24 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    This ^ most lift kits come with/recomend lean spacers. What lift do you have? Taco lean is because of the added weight on the drivers side, gas tank and battery. Stock suspension compensates for that. You need to add a 1/4-1/2" top plate spacer most likely depending on what lift you have
  7. Mar 5, 2013 at 6:25 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    True but he is probably leaning in the front also, if he corrects this it should help level out the rear
  8. Mar 5, 2013 at 6:25 PM
    BLK2012
    Joe
    AZ
    I have a 6" Maxtrac lift. I've heard of Taco Lean before but didn't know what it was. Its not a huge deal. Just was curious.
