Slight lift for 1st gen, single cab 4 bangers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bobwilson1977, Oct 26, 2009.
  1. Oct 26, 2009 at 8:00 AM
    bobwilson1977
    bobwilson1977 [OP] Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I've decided to keep my old truck until the wheels fall off. But I've also kind of wanted to give it a more aggressive look. Have any of you put bigger wheels/tires on your stock 2WD tacos?
  2. Oct 26, 2009 at 8:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Lots of 5 luggers have done this....Not sure if there is a lift that only gives a couple inches or so....Last I checked, seemed you had to get a long travle set up.....
  3. Oct 26, 2009 at 8:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  4. Oct 26, 2009 at 8:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. Oct 29, 2009 at 8:30 PM
    trailmaker
    trailmaker Well-Known Member
    northern ca
    4wd reg cab
    Here's my gold reg cab 4x4, to give you an idea of what it might look like.
  6. Oct 29, 2009 at 11:38 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    I got a 1'' lift:cool:
  7. Oct 30, 2009 at 8:00 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    body lift?????
  8. Oct 30, 2009 at 12:43 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    The first link is for 2005 to 2008.
    Will that really work on a 96 or 98? If so killer find.
    The second one is a nice way to go. but you need something for the rear.
    Going to a 15 rim and bigger tire will also help.
    It is tuff, I looked all over to find a lift for my truck, but in the end they cost a bit much. If you Took the money and sold the truck I could get a high milage 4X4.
    So i am holding off till I can afford a low milage 4X4 or new one.
    what is your Budget?
    if it s low the spacer and blocks might be for you..
