Slight miss?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VstarRob, Aug 28, 2016.
  1. Aug 31, 2020 at 2:51 PM
    #201
    CCL1977
    CCL1977 Member
    Wish I hadn’t just topped up with 87 before reading this. Delays my experiment. I couldn’t quite tell if it’s higher octane or the no ethanol that was the solution (or both). Most of the ethanol free around here is 87. I may just run premium for a couple tanks and progress from there. I imagine 91 “E free” would add close to 20 bucks to a full up.
  2. Aug 31, 2020 at 7:58 PM
    #202
    Knuckledragger
    Knuckledragger Well-Known Member
    Plymouth, MN
    2016 DCLB. 2003 xtra cab (sold). 5th Gen 4RSR5P (sold)
    2016 auto. Mine feels like it’s chugging in 4th gear at low rpms. It’s similar to when you’re in too high of a gear with a manual transmission.
  3. Sep 1, 2020 at 6:33 AM
    #203
    CCL1977
    CCL1977 Member
    Pretty sure mine does it in all the high gears, 4, 5, or 6. Any time the rpms are below ~1700 and you are on the gas while putting load on (typically a slight hill). If it drops a gear and rpms go up it goes away.
    That’s why most folks are noticing it on slight Uphill grades. The gas pedal is down a bit trying to keep speed but not quite enough to drop a gear. So it’s pulling hard at low RPM.
  4. Sep 1, 2020 at 8:04 AM
    #204
    teleslinger
    teleslinger Member
    2017 tacoma offroaed
    In my case, I ahve one of the rare 6 speed 2017s. Since I control the rpms manually through shifting, I tend to notice this much more at 2400-2600 than anywhere else in the powerband. The use of high test is significantly better. I hate spending nearly 50 cents more per gallon here in Kalifornia, but that is my reality. I have also bought some cheap after market octane booster. That helps as well. So it seems like compression and octane are in cahoots on this mystery. If not for this issue, I would say this truck is about perfect, given its size. But this issue niggles and pokes at me. I notice it every damn time it happens, and it happens anytime I am on a load climbing in that range.
  5. Nov 22, 2020 at 12:40 PM
    #205
    CCL1977
    CCL1977 Member
    It seemed that 93 octane helped. I’ve gone to 89 octane just to see but I’ve also got a shiftsense installed now.
  6. Nov 22, 2020 at 1:20 PM
    #206
    teleslinger
    teleslinger Member
    I have 32k on the truck. It seems A LITTLE better. I took mine to two different dealerships who said no codes, no evidence of missing, and claimed ignorance about the problem. For the second dealer, I brought a copy of the article that I had, which stated some 2017s are a recall because of cam issue and missing. --Nope, ain't never heard of that. I almost love the truck. But I traded a perfect Tundra for it...primarily for the gas mileage. So having to burn hi-test means my savings is de minimus. GRRRR. It's a great truck--almost. Is it worth taking a $5000 hit to replace it with another used Tundra? Or a 4runner? I don't know. It annoys me everytime I pull a load up a hill, and I tow a lot with small craft. I have 8 boats and build wooden boats.
  7. Nov 8, 2021 at 7:12 PM
    #207
    BlackburnPete
    BlackburnPete Blackburn Pete
    Blackburn Hamlet, Ottawa, Ontario, Canada
    2017 TRD OR AC MT Black
    I, too. have the unicorn 2017 Off Road Access Cab with a manual 6-speed and I have just ran a couple of tanks of Shell Nitro Plus 91 with zero ethanol (E0) and the performance boost is nice, but the stuttering acceleration is still the same. On a slight acceleration at 2000 - 2500 rpm, it has a definite and repeatable shudder, hesitation, or slight missing which only stops if I push the pedal hard or back off.
    I rarely need to bomb around at or above 3000 rpm, but the truck runs perfectly if I am heavy on the gas pedal. This is very noticeable in cruise control at highway speeds when a slight uphill is encountered. I am currently Coyoza tuned and running a K&N air filter (not CAI version). I might try KDMAX XXT tune next.
  8. Nov 10, 2021 at 8:00 AM
    #208
    Badname
    Badname Well-Known Member
    Socal
    2018 Tacoma Sport AT
    OVTune 2.0 premium Taco rail universal holder Falken wild peak A/T 265/65R17 Center console tray
    Mine did it once in a long while before the fuel pump recall and now it does it more often.
  9. Nov 18, 2021 at 3:19 PM
    #209
    BlackburnPete
    I just got the Overlander tune from Yotatune in Ottawa, Ontario. So far, the slight miss, or stuttering on acceleration is gone. Now it is just a nice smooth acceleration without having to gear down on the highway. Even in 6th gear at 100km/h, there is smooth acceleration up to 120 km/h without pushing in the clutch and downshifting to 4th or 5th.
