Slight miss?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VstarRob, Aug 28, 2016.
  1. Jan 20, 2017 at 2:00 PM
    #101
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Sounds like horse manure.
  2. Jan 20, 2017 at 2:00 PM
    #102
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    The CEL will only be triggered if misfire counts are beyond a certain threshold. Counts below the threshold will not log as an issue. But he's right....if misfires were the cause of the surge, I've logged plenty of time on a slight uphill incline where it's surging for a good 10+ seconds and it doesn't trigger a CEL, so I am very skeptical the surge is a misfire.
    And you'll still have it with rev 1...it's the ECU tune, not the TCU.
  3. Jan 20, 2017 at 2:00 PM
    #103
    bradwhitenikki
    Brad
    Exactly.
  4. Jan 20, 2017 at 2:02 PM
    #104
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    They wouldn't even look at the data where it logged 7 misfires on cylinder one. The sassy service counter rep scoffed at me.
  5. Jan 20, 2017 at 2:06 PM
    #105
    nm4553
    Nick
    NEPA
    2017 DCSB TRD Sport
    The surges I've experienced haven't been that bad..maybe 3 shorts surges or so at most. Low rpm for an extended period and then when I press the throttle a bit more it will hold, hold, hold that low rpm - surge - then throttle will respond. I will not be filling with ethanol free so that when I take it back in they can hopefully replicate the issue with their Techstream or whatever they use.
  6. Jan 20, 2017 at 2:09 PM
    #106
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Keep in mind the way it's detecting a misfire is by looking at the speed of the crankshaft and those sensors aren't perfect...so count results aren't perfect either which is why there's a threshold in the amount of misfires counted before it will trigger a CEL.
  7. Jan 20, 2017 at 2:22 PM
    #107
    nm4553
    Nick
    NEPA
    2017 DCSB TRD Sport
    Thank you for the 411. This is good information to have on hand. Would a tech be theoretically able to lower that threshold for the sake of diagnostics? Say, force the truck to throw a CEL after a certain # of misfires?
  8. Jan 20, 2017 at 2:26 PM
    #108
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Not that I've ever seen...but my experience is limited to tuning using piggyback ECUs and reflash utilities that may not give the same level of diagnostic options.
  9. Jan 20, 2017 at 3:16 PM
    #109
    nm4553
    Nick
    NEPA
    2017 DCSB TRD Sport
    Too late to lose hair over this now. It's time for a drink. Cheers y'all.
    nevadabugle likes this.
  10. Jan 20, 2017 at 3:22 PM
    #110
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    :cheers:
  11. Jan 20, 2017 at 4:18 PM
    #111
    david3821
    david3821 Well-Known Member
    2016 Silver Tacoma TRD Off Road
    My fix has been to stomp on the gas in anger and yell....what a piece of S**T... at the top of my lungs. This engine/tranny combo is seriously the worst out of any vehicle I've ever owned.
    In all seriousness, I'll try higher octane or boat gas and see if it helps.
    Also, I'm hoping Rev1 will help a little. I'll request it during my upcoming 10k service.
    mr2r6 likes this.
  12. Jan 20, 2017 at 6:20 PM
    #112
    mcmmotorsports
    mcmmotorsports Well-Known Member
    Michael
    2016 MGM Tacoma TRD OffRd Access Cab
    I think the only fix would be an LS3 swap. :crapstorm:
    bradwhitenikki likes this.
  13. Jan 20, 2017 at 6:51 PM
    #113
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    It is probably all in my head but I have tried running premium fuel three separate times (purely for this reason) and it did seem to help a bit. YMMV.
    I really want to keep this truck long-term so I'm desperate to eliminate these little annoyances. Hopefully they'll develop an ECU flash for this. There is no way Highlander or Sienna buyers would tolerate this so Toyota must have some better programming available.
  14. Jan 20, 2017 at 6:55 PM
    #114
    bradwhitenikki
    Brad
    Toyota... hacked
  15. Jan 20, 2017 at 8:16 PM
    #115
    PNUT
    PNUT Snake is just sneak spelled sideways
    North Bay
    2016 Tacoma DCSB TRD OR 4X4
    Ray 10s Prinsu Switch Pro
    i just took my truck in a week ago for this issue, made the lead service advisor ride with me to replicate while hooked up to tech stream. It didn't show any misfires. When trying to hold a constant speed, my truck shifts to 5th (AT) and holds 1100 rpms, whether 35 or 45 mph. This is when I feel the lugging, surging, misfire type sensation. I've had an open case with corporate for months, and have had both AT software revisions. I'm Going to get the regional rep out here and make him come on the next ride along.
    mr2r6 and mcmmotorsports like this.
  16. Jan 21, 2017 at 1:16 PM
    #116
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Well..I'm really not sure now, 250 miles after filling back up with 91 E0, the learning for this fuel seems to have virtually eliminated the surging...I can't seem to reproduce it for the life of me now. I wasn't taking logs over the last 150 miles or so, but something's adjusted for the better on this fuel. Again...I'd strongly advise running E0 fuel if you can and see the difference it makes after a tank's worth of learning or so.
  17. Jan 21, 2017 at 1:24 PM
    #117
    nevadabugle
    Elko, NV
    I run nothing but ethanol free 88 octane. And it still does it. Again mine went away for a few months for no reason besides warmer temperatures. Could it be the winter blend fuel?
  18. Jan 21, 2017 at 4:16 PM
    #118
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I also run E0, but we can only get it at 91 Octane in my neck of the woods. I can tell you I've had this "fishbite" surge since day one, regardless of the season. Lower octane fuel makes it worse, which is why Scooby's data on timing being pulled makes sense to me.
    Do you guys think the engine could be switching over to OTTO mode under increased throttle demand/load at the point that the timing is pulled? I mean, almost 12:1 compression ratio on 87 Octane??? I know that direct injection would help mitigate this... thoughts?
    Frank
    nevadabugle[QUOTED] likes this.
  19. Jan 21, 2017 at 4:38 PM
    #119
    bradwhitenikki
    Brad
    I think so Frank, but I have not confirmed yet. Agreed on the direct injection as far as detonation is concerned, but there are other "burn rate" related reasons for retaining the timing when switching to Otto.
  20. Jan 22, 2017 at 4:20 PM
    #120
    mcmmotorsports
    Michael
    The only E0 fuel here in Connecticut is race fuel. Not dropping $10+ a gallon for this
