Slight miss?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VstarRob, Aug 28, 2016.
  1. Feb 23, 2017 at 6:56 PM
    #161
    JLatsTaco
    JLatsTaco Member
    Fort Knox KY
    2016 tacoma offroad 4x4
    after 2 tanks, can you go back to regular gas or will the issue come back if I do? Thanks for your help.
  2. Feb 23, 2017 at 6:57 PM
    #162
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I've noticed my Tacoma has started dieseling at times when I shut it down. I wonder if this has any relation to the misfire issue or what could be causing it.
  3. Feb 23, 2017 at 7:03 PM
    #163
    mcmmotorsports
    mcmmotorsports Well-Known Member
    Michael
    2016 MGM Tacoma TRD OffRd Access Cab
    No, the issue will come back once you switch back to 87 E10.
  4. Feb 23, 2017 at 7:16 PM
    #164
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Dieseling? Holy fuck that's not good...my 1970 chevy running on only 7 cylinders does that but a 2016 Fuel Injected engine? Is that even possible.
    Tharris242 likes this.
  5. Feb 23, 2017 at 7:22 PM
    #165
    BBoyM3
    BBoyM3 Well-Known Member
    Bobby
    San Antonio, TX
    2025 White DCSB TRD OR
    Predator Tube Steps, Spray-In Liner, Toyota Larger Mud Guards, Expel PPF, Expel Tint (35% Fronts Only), NXTZEN Paint Coating, 17x8.5 +25 RRW RR5-S Black, and 285/70R17 Toyo AT3
  6. Feb 23, 2017 at 9:37 PM
    #166
    smitty99
    Scottsdale
    Yes it's like a slight run-on or stumble after I push the button to kill the motor. Weird.
    nevadabugle[QUOTED] likes this.
  7. Feb 24, 2017 at 3:42 AM
    #167
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yeah I'm with Nevadabugle, how does that even happen on a modern EFI engine? Unless it's got something to do with the pushbutton start weirdness.
    I will tell you that there's a different (but maybe related) little quirk that happens to me at startup, but ONLY when the truck has been shut down for a short time - it will start so quickly that the starter winds up before my melon realizes what's going on and I release the key. Sounds like there's a bit of unburned gas/vapour in the cylinders at shutdown. Anyway, just thought I'd relate..
    Frank
  8. Feb 24, 2017 at 8:14 PM
    #168
    david3821
    david3821 Well-Known Member
    2016 Silver Tacoma TRD Off Road
    So you're right, after a few gallons of fuel burned, I haven't had any issues. Well, except for the whole paying $2.89 for non-ethanol vs $2.15 87 E10.
    Don't know if can afford boat gas for my truck and my boat!!!
    Inferno500 likes this.
  9. Feb 25, 2017 at 2:06 PM
    #169
    JLatsTaco
    JLatsTaco Member
    Fort Knox KY
    So if in fact that the issue is going away with a non-ethanol fuel, what can we contribute the issue to? If we can narrow it down, then we might be able to fix it on our own. Any suggestions?
  10. Feb 26, 2017 at 6:57 AM
    #170
    JLatsTaco
    JLatsTaco Member
    Fort Knox KY
    Just got done checking the trans fluid level myself. Guess what, nothing came out, not even a drip!!!!! This is after the dealership added a quart, field tech came and rode with me, 10 trips to the dealership. I wish I would have checked it myself after the dealership added the fluid. Now I have 6000 miles on the truck driving around with low fluid. For all that are having issues with this, please check the level yourself. It is not hard. I used a paperclip to connect the 4 and 13 port of the obd11 port, shifted from n to d 3 times ( i thought it was 6 but it did it at 3), the d, n, r, p, light will go off, thats how you know you are in check mode. It took approximately 25 minutes for it to go into check mode from a cold start first thing this morning. Now I tried calling corporate and the field tech but no ones home being Sunday. Tomorrow is going to be interesting to say the least!
  11. Feb 26, 2017 at 10:24 AM
    #171
    nevadabugle
    Elko, NV
    Ummm...did you post this the wrong place. I want you to get the answers your after but not sure this thread will give you those answers.
  12. Mar 28, 2017 at 5:42 PM
    #172
    mr2r6
    mr2r6 Well-Known Member
    Charleston, SC
    16 TRDOR 4X4
    Any updates from anyone? I tried the ethanol and cant say it really helped. It was only one tank though. I think I will try to check my tranny fluid level myself too. I has the dealer do it and they added a tad, but I don't trust them.
  13. Mar 28, 2017 at 5:54 PM
    #173
    mcmmotorsports
    Michael
    Two tanks of E0 to really notice a difference
  14. Mar 28, 2017 at 6:12 PM
    #174
    nevadabugle
    Elko, NV
    This.
    mr2r6 likes this.
  15. Apr 6, 2017 at 2:18 PM
    #175
    Cheers007
    Cheers007 Well-Known Member
    DFW
    2017 Tacoma Limited
    Mine does this too, but I don't really care cuz it does not post any codes on my scanner. To get rid of that, just give it more throttle to unlock from the torque converter and raise RPM.
  16. Apr 6, 2017 at 2:23 PM
    #176
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    With ect and s mode combined, it keeps cruising rpms above the surging point and generally makes life in this truck much more pleasant. Not a solution for you stick owners but I'm actually running 87 e10 right now and not bothered at all because these modes prevent the conditions where the surge occurs.
  17. May 29, 2017 at 6:57 PM
    #177
    mr2r6
    Charleston, SC
    16 TRDOR 4X4
    Any new on a fix for this? I'm in need of service and about to take the truck in. I'd love if Toyota came up with a fix to have this issue behind me so I can enjoy the truck.
  18. May 29, 2017 at 7:41 PM
    #178
    nevadabugle
    Elko, NV
    Ethanol free is what I have found fixed this. I know it's not a real fix but it does make it go away.
  19. May 29, 2017 at 7:50 PM
    #179
    mr2r6
    Charleston, SC
    16 TRDOR 4X4
    Yeah I get that and it's awesome this community has figured it out, I'm very appreciative. I just wondering when Toyota will come up with a fix. Ive made a stink of it every time I go in for service, but nothing every happens. I was hoping maybe a new map or reprogram has come out.
  20. May 29, 2017 at 7:53 PM
    #180
    nevadabugle
    Elko, NV
    No real fix that I have heard about.
