Slight Rear Rake...need help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by netclear, Apr 26, 2010.
  1. Apr 26, 2010 at 11:33 AM
    netclear
    netclear [OP] Member
    Edmonds, WA
    05 Tacoma DC 4WD
    3" RevTek Lift / 5100's
    First off, I really appreciate TW and all that contribute as I spent a solid 2-3 weeks reading thru threads and viewing photos of other Tacomas to determine what I wanted to do. It was immensely helpful...so thx to all of you who participate.
    I have recently purchased a 2005 DC LB 4X4 and after much deliberation I decided to perform the following;
    3" RevTek leveling kit (spacers in front AAL in rear)
    Bilsteins front and rear (fronts set at 2.5)
    MotoMetal 955's (17x9 Machined)
    285/70/R17
    It may be the weight of the Tonneau (approx 100lbs) but the rear squats about 1/4 inch...It bugs me pretty bad. I want to level the truck and need some guidance on options. I really do not want to adjust the Billys in the front down to 1.75. Nor do I really want to block the rear. The truck is primarily a commuter and daily driver, although I willl be hauling MX bikes, boats, and enclosed trailers. Should I invest in bags to level the truck under load as well as gain the 1/4 to 1/2 inch I am looking for during daily use? What are the pros and cons? Thanks in advance for any guidance or suggestions (experiences).
  2. Apr 26, 2010 at 11:47 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'm confused....
    What exactly do you have in the front?
    3" spacers?
    OR
    the bilsteins set at 2.5"?
    You can't physically (or shouldn't) have both.
  3. Apr 26, 2010 at 12:09 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    x2 I iz confuzed :notsure:
  4. Apr 26, 2010 at 12:14 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Looks perfectly level to me:confused:
    And you're stressing about 1/4"?? Dude, that difference could be how your parked or something
  5. Apr 26, 2010 at 12:18 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I'd be more concerned about getting that door molding off asap :p
  6. Apr 26, 2010 at 12:24 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    Looks leveled to me. .. And yes, the molding must go.
  7. Apr 26, 2010 at 1:01 PM
    Herculean
    Herculean Active Member
    Brandon
    SoCal
    A/R Chambers, BFG KM2's, Donahoes, Fox 2.0, Sliders, flowmaster, some little stuff.
    I have a set of 1/2" aluminum blocks sitting on the shelf that I had on my 05 if you want them. They work fine with the stock U-bolts... just pop em in.
  8. Apr 26, 2010 at 2:47 PM
    netclear
    Edmonds, WA
    05 Tacoma DC 4WD
    I didn't install the kit, rather had a local shop do it as a complete package with Wheels and Tires...my assumption was that the shocks would be set to match the AAL. But clearly there are spacers installed so the shock must be set at stock setting "0"???
    Either way, I willl need to gain a small elevation in the rear to address the "sag" as I will be unable to adjust the front (without removing the spacers and setting the shock/coil).
    Ya'll don't appreciate Grandpa's custom door moulding? I bought the truck from a gentleman who was retiring and heading to Arizona...He took great care of teh rig and was quick to point out his custom moulding. He thought it was really a strong selling point!:eek:...funny stuff. Guess I will have to tackle that later.
    still wondering about solutions when towing though...to address teh loading when tongue weight applied.
    Thanks!
  9. Apr 26, 2010 at 2:58 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The easiest way to fix this is to remove the spacers and set the billy's to 2.5. That will give you a much better ride, and it will lower the front 0.5 inches. Best of both worlds.
  10. Apr 26, 2010 at 4:03 PM
    netclear
    Edmonds, WA
    05 Tacoma DC 4WD
    Thanks KPT...I will adjust accordingly.
  11. Apr 26, 2010 at 4:27 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    those dont look like billys to me. The billstein 5100's are a brushed stainless steel look, not black.
    looks like you have just a spacer lift. As for the rear, if your gonna be towing and not really any offroading I would look at the air bag helper kits, they are pretty straight forward and can adjust to your load
  12. Apr 26, 2010 at 5:17 PM
    KPT
    09 Prerunner
    That could be the angle of the picture. The billy's have a sliding plastic sleeve a few inches long at the top to protect the shock.
    OP: is the metal part of your shocks silver or black?
  13. Apr 26, 2010 at 6:32 PM
    netclear
    Edmonds, WA
    05 Tacoma DC 4WD
    They are silver at the base (brushed aluminum look), they are Bilsteins. In the attached photo you can just make out the black plastic cover at the top.
  14. Apr 26, 2010 at 6:39 PM
    KPT
    09 Prerunner
    Yep, those are the 5100's. Take it to the shop and tell them to take the spacers off and set the bilsteins at the highest setting.
    Spacer lifts are junk anyways.
  15. Apr 26, 2010 at 6:45 PM
    KPT
    09 Prerunner
    Or if you want a little more rake you could set the billys at 1.75". That's the second highest setting.
  16. Apr 26, 2010 at 6:55 PM
    netclear
    Edmonds, WA
    05 Tacoma DC 4WD
    I like your first suggestion, I don't want a chicken-hawk look, just a slight positive rear. You nailed it when you said that I would gain a half inch using the shocks adjustment. this will change the trucks telemetry from 1/4" lower in the rear to 1/4" lower in the front...exactly what I am looking for...and, hopefully like you said I will gain a better ride (less stiff up front), it isn't terrible right now but is is noticeably stiffer than pre-spacers. thx for advice.:)
  17. Apr 26, 2010 at 7:31 PM
    KPT
    09 Prerunner
    No problem. Report back with the results.
  18. Apr 26, 2010 at 8:02 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yea I forgot the billys came with those black plastic covers.
