Slight shimmy in steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bob's 07 Tacoma, Jun 22, 2009.
  1. Jun 22, 2009 at 2:28 PM
    Bob's 07 Tacoma
    Bob's 07 Tacoma [OP] Member
    St Marys Co.Maryland
    07 PRERUNNER TRD SPORT
    Help! Ever sence trk was new had this problem.took OE Dunlops off & replaced with Michelin AT2's..same problem.also trk seems very loose in steering at higher speeds..Trk has 14000 miles on it now.
  2. Oct 12, 2013 at 9:07 AM
    Litaker
    Litaker Member
    2010 SR5 4x4 Manual 2.7L
    Its either out of round tires or out of round rims. I have a 2010 tacoma that I bought with 10700 miles that has the same issue, 2 different sets of tires, and still vibration. After 8 balances at 4 different shops, this is my conclusion. On a balancer the tire bounces around and has a noticeable hop. Start at the rims on a spin balancer and look for imperfections and wobble or out of round from the center. Then mount the tire on a good rim. If it wobbles, then your tire is out of round, defective, or improperly installed and damaged. Good Luck!
    http://www.agcoauto.com/content/news/p2_articleid/110
    http://tires.about.com/od/wheel_safety_maintenance/a/Diagnosing-Wheel-Vibration_2.htm
    http://www.tirerack.com/images/tires/vibechart.pdf
