Slight shudder but smooth idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by ztwatson, Jan 10, 2024.
  1. Jan 10, 2024 at 6:40 AM
    ztwatson
    ztwatson [OP] Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Hey guys I get a slight shudder/jostling or what I believe is the engine when at idle. The idle is super steady right around 750. Overall the truck runs great but I’m just curious as to what would cause the shudder with it running so smooth. Timing belt water pump etc just got done as well as spark plugs. Shudder has been there for a long time.
  2. Jan 10, 2024 at 8:24 AM
    Glamisman
    Glamisman Well-Known Member
    2.4, 2.7 or 3.4 motor?
    I am assuming that you mean if has a rough feeling in the cab… The 4 cylinders are known for a rough idle in the lower rpms. As a test put a block of wood on a floor jack and put it under the oil pan and lift it slightly to see if the shudder goes away. Motor mounts and trans mounts have a tendency to loose their suppleness over time and transfer more vibrations to the frame.
  3. Jan 10, 2024 at 8:35 AM
    ztwatson
    Milwaukee, WI
    3.4L. Yeah you basically feel the shudder in the seat of the truck. Almost something you would associate with the truck running rough but she purrs pretty smooth which is why I’m confused.
  4. Jan 10, 2024 at 10:08 AM
    YungSprung
    YungSprung Well-Known Member
    Video
    What is a Shudder
    Probably rocks and shit in your fuel injector baskets
    dribble dick
  5. Jan 10, 2024 at 10:47 AM
    ztwatson
    Milwaukee, WI
    The engine slightly moves, shakes, vibrates etc. similar to what you would have with a misfire or running rough. Not sure it would even show up on camera but I’ll see if I can get something.
  6. Jan 10, 2024 at 10:54 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    @ztwatson Can you send over a video clip? I had a rough idle that was turned out to be a dirty Throttle Body. I cleaned up the TB and the idle smooth out. Maybe that's the issue???
