Slight squat after lifting
Discussion in 'Suspension' started by captain_beefheart14, Dec 28, 2021.
  1. Feb 24, 2022 at 7:40 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I understand a tire/alignment shop might not have the tools but any auto mechanic shop worth their salt would be able to do this and have a wall-mounted spring compressor. No shop I've ever heard of charges $500 for what you are asking, it's a very simple job that even I could probably do in an hour. Seriously would consider finding a new shop or at least only doing tires/alignment at this one particular place.
    As I said before be careful and make sure you know what you are doing. It can be done with the tool you linked to but it's sketchy. Those things are nicknamed "death sticks" by some people so take from that what you will. Go watch some YouTube videos and see some results. I'd feel safer using the floor jack method but neither one is really all that good or safe.
    Yes it's going to sag. No you probably can't add leafs back but heck if I know. If it was my truck I wouldn't Frankenstein it together like that especially on a nice new 2019 model. AAL setups are the cheap route to get lift, they don't help increase load capacity / fix sag. The real fix is to buy an actual purpose-built spring pack to handle more weight.
  2. Feb 24, 2022 at 10:17 AM
    captain_beefheart14
    captain_beefheart14 [OP] Well-Known Member
    2019 Cement Off Road
    Prinsu racks, cab and top, light bar, rear and side roof rack lights, ARE Camper shell, blackout, TRD Grille, Anytime front and rear cameras, Truck bed box (DIY) Bilstein 5100 front, OME 2885 Coils, Ikon Stage 2 Rear AAL
    Sounds like I'm gonna have to dump more money either way. thanks for the advice!
  3. Feb 24, 2022 at 11:46 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    You can use the vehicle as a spring compressor, its safer, and easier than a spring compressor. There is also a better style spring compressor on Amazon too.
  4. Feb 24, 2022 at 12:03 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Have you looked into the Icon RXT leaf pack? There's 3 lift height options... if you tow or carry more weight try option 2. Here's my truck with a 2" coliover lift up front and the rxt pack with the weight of my canopy at option 2. Hub to fender front 22"... 24 1/4" in back... thinking the leafs will settle to 24".
  5. Feb 24, 2022 at 1:34 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Just put Deaver u402 stage 2 or 3s or icon rxts in the back and call it good.
  6. Feb 24, 2022 at 4:47 PM
    captain_beefheart14
