Slight squealing/chirping noise while driving...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solution.45, Feb 22, 2017.
  1. Feb 23, 2017 at 3:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The only reason mine was that loud is because when I filmed it, I had no carpet in my truck, and I removed the grommet in the floor so I could accurately capture it on video. During normal driving, I'd only hear it with the window down, music off, and driving next to a car or wall.
  2. Feb 23, 2017 at 3:24 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    That sounds like it varies with load, carrier bearing makes sense.
    No. I bought extended warranty out to 100K miles when I bought the truck new.
    EatSleepTacos[QUOTED] likes this.
  3. Feb 23, 2017 at 3:24 PM
    Solution.45
    Solution.45 [OP] Well-Known Member
    Chase
    Redding CA
    2011 White 4x4 double Cab
    After I sent the message my brain kicked in and realized that haha. But yeah Im going to have to take it in and get it looked at.
  4. Feb 23, 2017 at 3:26 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    For me, when it would rain the squealing would go away. My hunch was that the water would act as a lube and stop the noise.
    EDDO likes this.
  5. Feb 23, 2017 at 3:35 PM
    Solution.45
    Chase
    Redding CA
    Smart man! Im debating on whether or not taking it to the "stealership" or a local shop. I had a bad experience with my last tacoma and the drive shaft after taking it to Midas so I will never again go to them. The carrier Bearing looks absolutely fine and no major movement at all so Im leaning towards the rear wheel bearing.
  6. Feb 23, 2017 at 3:44 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Thought I had wasted the money it cost as this was the first claim and the truck has been flawless. Until now.
  7. Feb 23, 2017 at 4:09 PM
    Solution.45
    Chase
    Redding CA
    Im hoping its not too expensive. Maybe around 500 or so im guessing if its the CB. The wheel bearings I dont know anything about.
  8. Feb 23, 2017 at 4:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The CB itself is like $80, and the install shouldn't be more than a couple hundred dollars. It's not too complicated.
  9. Feb 23, 2017 at 4:49 PM
    Solution.45
    Chase
    Redding CA
    Thats not bad at all. I was looking at a video of a bad wheel bearing and mine sounds nothing like that. Now my OCD is kicking in....shit!
  10. Feb 24, 2017 at 10:21 AM
    Solution.45
    Chase
    Redding CA
    So i just took it to a shop and they are saying the carrier bearing is fine which i also think is fine as well. They think its inside the aft end of the drive shaft...what could that be??
  11. Feb 24, 2017 at 10:41 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Pinion bearing? Might be time to take it to a driveline specialist. http://www.driveshaftpro.com/san-diego
  12. Feb 24, 2017 at 10:57 AM
    Solution.45
    Chase
    Redding CA
    I no longer live in SD I live in Ventura. I appreciate the reference though. The guy at the shop was telling me that the enite drive shaft would need to be replaced which would end up being around $1800. To me that sounds alittle excessive.
  13. Feb 24, 2017 at 10:57 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have no idea as I'm not too mechanically inclined. My bet was on the CB.
  14. Feb 24, 2017 at 10:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Uh, yeah. That's way excessive. There have been people on here who have had a custom one piece drive shaft made and it cost them like $500.
    I'm also from the area. Grew up in Thousand Oaks!
    EDDO likes this.
  15. Feb 24, 2017 at 11:03 AM
    #35
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    http://www.driveshaftpro.com/ventura
  16. Feb 24, 2017 at 11:06 AM
    #36
    Solution.45
    Chase
    Redding CA
    Rad dude! I appreciate your help and hopefully this can be easily taken care of instead of paying 1800 like that jerk off told me.
  17. Jul 11, 2019 at 4:18 PM
    #37
    Matt Marin
    Matt Marin New Member
    2002 Pre-Runner Ex Cab
    Did you ever figure this one out?
    It sounds like I have the same noise you had.
    Update - I had a a major service that included installing new carrier bearing. That's when noise started. The shop thought it was the rear breaks but they have ruled that out. Now I'm wondering if it's the new carrier bearing itself or a slight misalignment created by the new CB that is causing the u-joints to make the sound. It's driving me kinda nuts trying to find it.
    If you found a definitive fix let me know. Thanks!
  18. Nov 8, 2019 at 2:13 PM
    #38
    Whitetacomacalifornia
    Whitetacomacalifornia Well-Known Member
    Steven
    2011 Tacoma DCLB
    Mid travel with camburg arms and fox dsc coilovers. Rear SUA soon
    I also have this noise after installing long travel. Hopefully someone can chime in on a what they might think it is?
  19. Nov 8, 2019 at 6:48 PM
    #39
    TRD 4.0
    TRD 4.0 Well-Known Member
    Jorge
    CA
    06 4x4
    Bilstein 5100, BFG KO2 265/70/17, BHLM, 4th gen 4runner SE 17s
    I have a slight chirping noise going over rough roads. Turns out its the front bumper thats a little loose
  20. Nov 8, 2019 at 7:03 PM
    #40
    Steven
    2011 Tacoma DCLB
    That's why I run a tube bumper!
    I think my squeeling is the carrier bearing.picked one up and hopefully gonna change it tommorow.
