Slight Stutter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Postal_Dave, Mar 9, 2024.
  1. Mar 9, 2024 at 7:05 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    My current 2023 sr5 v6 idles super rough in gear. Waiting for a field tech to come look at it.
  2. Mar 9, 2024 at 8:05 PM
    Postal_Dave
    Postal_Dave [OP] Member
    Dave
    2023 Red Access Cab SR V6 4x4 Tacoma
    I hope you're still under warranty.
    Gfenza89 likes this.
  3. Mar 10, 2024 at 5:10 AM
    Gfenza89
    Only has 3500 miles
  4. Mar 10, 2024 at 5:34 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    You are pretty close here. This is the shudder many of us experience. It is the transmission logic trying to stay in the higher gear, knowing that if it could, for just a few seconds longer, it wouldnt have to lock the torque converter, or shift to 5th, or fourth, then right back to 6th, in a few seconds. I liken it to a vehicle, (motorcycle or automobile) with a manual transmission, slightly in the wrong gear, and needs a downshift but, we ride it out. The engine logic calls for a shift or locking the converter, due to rpms, load and throttle position,but, the translogic either says yes too late, or preemptively shifts or locks too early. You get the shudder or the shift dance, down, up, down up... Even on flat ground. Driving with your foot can mitigate it, driving in cruise calls for more shifts down, than locking the converter, for the extra rpms the logics are asking for. It is what it is. some of us are more sensitive about it, than others. Ski
  5. Mar 10, 2024 at 8:05 AM
    Postal_Dave
    Dave
    So to counteract the stutter/shudder, I could use the manual shift and put it 5th and go from there. It may use a little more gas but it will be a smoother ride. I wonder if putting it in "Tow Mode" would help with this.
  6. Mar 10, 2024 at 8:15 AM
    skidooboy
    central lower mich
    leave in 4th below 50, leave in 5th below 60. If it keeps doing the dance, drop a gear. Ski
  7. Mar 10, 2024 at 8:27 AM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    My 2021 has the stutter as well. I feel it when going up a particular hill on my commute home. I usually just mash the skinny pedal or throw it into S mode. It bugs me a bit, but I don't think there is a problem, it's just the way the truck works...
    Love my Truck~~
  8. Mar 10, 2024 at 11:15 AM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    Same thing here, there is an incline that drives me crazy on the way home from work. I think I found a way to reduce the stutter by exerting a certain amount of pressure on the gas pedal. There is a dead spot in the pedal travel where my speed won't change with varying pressure, but the truck seems happier when I'm pushing on the lighter end. Oddly enough, I have also climbed the hill with cruise control engaged and however the truck calls for power in CC keeps the stutter at bay. Lots of quirks
  9. Mar 10, 2024 at 2:35 PM
    Postal_Dave
    Dave
    I've noticed a dead spot too. It's small but it's there. I figured that it was a computer thing because the throttle body is controlled by wire.
    Canadian Caber likes this.
  10. Mar 12, 2024 at 6:53 AM
    WarwickE36
    WarwickE36 Member
    2023 TRD Sport
    I have the same issue in my 2023 TRD sport. As a tech of 20 years (recently turned to being a parts guy) it drives me nuts. I spent most of my life looking for vehicle issues, and I can't turn off that skill. I got a pedal commander and it makes controlling the issue using the pedal a lot easier. I was "anti" pedal commander until I bought this truck. Without it I might have gotten rid of it before hitting 2k miles. I feel like you can feel EVERYTHING in this truck. My stock tires had a vibration at 53mph... I swapped my TRD wheels with Falken Wildpeak AT3's from my 4th gen 4runner onto it and it was still there. I went down the rabbit hole measuring driveline angles and checking U-Joints... nothing. Finally got pissed enough and bought Michelin Defender LTX M/S tires last weekend.... the vibration is gone, thank God. But I do still feel everything on the road. I am considering swapping the rear shocks to the OR or Pro shocks.
    Postal_Dave[OP] likes this.
  11. Mar 12, 2024 at 8:25 AM
    radbrad311
    radbrad311 Member
    2023 DCLB TRD OR
    I swapped the rear shocks on my OR to 5100s (haven't done the front yet) and it made a big improvement in ride quality and dynamics. The ORs feel underdamped stock not sure if it is the same for the Sports.
  12. Mar 12, 2024 at 8:34 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
  13. Mar 12, 2024 at 8:40 AM
    Canadian Caber
    Les
    B.C. Canada, eh
    For my 30 minute city commute I just leave my truck in S-4 with ECT on. For me it makes for a more enjoyable driving experience. I've found a roughly 1mpg hit. YMMV.
  14. Mar 12, 2024 at 11:19 AM
    CountryNP
    CountryNP Member
    My 19 does the same. I have noticed it goes away if I use the cruise control.
    Postal_Dave[OP] and AZPhys13 like this.
  15. Mar 12, 2024 at 12:24 PM
    #35
    WarwickE36
    WarwickE36 Member
    2023 TRD Sport
    I had 5100s on my 4th gen 4Runner and liked them. I was considering them or 4600's for my Taco. Something has to give with this setup. With an empty bed it feels like the rear tires are skipping even on smooth pavement from 50-65mph. With 200lbs of sand in the bed it is MUCH better.
  16. Aug 15, 2024 at 8:34 AM
    #36
    WarwickE36
    WarwickE36 Member
    2023 TRD Sport
  17. Aug 17, 2024 at 6:05 AM
    #37
    Junior314
    Junior314 Well-Known Member
    Northeast
    '17 MGM OR DC/SB
    Cosmetic.
