Slight vibration during acceleration at low speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zebra1963, May 25, 2024.
  1. May 25, 2024 at 9:04 PM
    Zebra1963
    Zebra1963 [OP] Member
    Zebra
    Been lurking around for an answer to my issue, but decided to dive in and create an account. I've seen lots of vibration issue questions and many answers, but haven't found a solution.
    I've got a 2012 Taco V6 4x4 Double Cab 6 ft. bed with 213400 miles, never had a major problem. Bought it in 2018 with 127000 miles. Regular oil changes, tire rotations, and all the other checks from a reputable dealer in Puyallup, WA. A few months ago I decided to do my own oil changes since my warranty expired. I know how to change oil by the book, done it for years even before I had the Taco. The only things I've done myself are front brake pads a couple years ago and starter replacement a few months ago. About a month ago I noticed a slight vibration when accelarating from around 20 mph. It continues to vibrate to around 40 mph, then goes away. Today I got the wheels rotated and balanced from the company I bought the tires from three years ago, thought the vibe would go away, but it hasn't. My next steps: maybe U-joints on the drive shaft? On the forum I've read about struts being a possibility. Tranny issues? No idea. I saw that someone greased the zirks on the U-joints and that solved it. I'll try that tomorrow. Any other ideas from someone with a similar issue will be appreciated.
  2. May 25, 2024 at 10:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Any squeaking in reverse?
    Might still be worth it to drop the driveshaft and check the u-joints
    Robnik and TnShooter like this.
  3. May 26, 2024 at 12:05 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This and the carrier bearing would be my first places to look.
    Robnik likes this.
  4. May 26, 2024 at 12:25 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Yes, I agree with Alex & Deogee. Those carrier bearings are known to fail at any mileage.
    Push on the driveshaft & check for "play". Might as well change the U-joints while you're at it.
    Good luck :)
    Bagman likes this.
  5. May 26, 2024 at 11:13 AM
    Zebra1963
    Zebra
    Thanks all!! I'll check the drive shaft this afternoon and report back. Cheers!
  6. May 26, 2024 at 11:43 AM
    Skunny
    Skunny Well-Known Member
    Ken
    Redlands
    2014 4x4 TRD Sport DBC
    I’m currently refreshing parts on my 2014 4x4 with 200k miles. I was experiencing vibrations when accelerating and braking. I replaced the carrier bearing and u-joints after dropping the drive shaft. The vibrations are now 99% better, but not completely gone.
    TnShooter likes this.
  7. May 26, 2024 at 10:18 PM
    Zebra1963
    Zebra
    I have a family emergency to deal with right now, so I might not get to the driveshaft check right away. But I did have time to find out the cost for a carrier bearing replacement, between $300 and $400. If that's accurate, I might just bite the bullet since it looks time consuming and possibly having to rent tools I don't have. But driveshaft check first, maybe tomorrow. Thank you Skunny for your later input. I'm hoping what you did helps me. And I wonder if you've had your wheels balanced recently. That might take care of the 1% vibe.
  8. May 28, 2024 at 9:20 PM
    Zebra1963
    Zebra
    Update: I greased the two rear u joints, and the vibration seems to have gone away. Weird that it would solve the vibration problem. But I'll give it a week. Meanwhile I ordered a set of three u joints plus the carrier bearing from Amazon for $75. Great reviews, we'll see. First I'll replace the front u joint which has some play and won't take grease. Hopefully this will solve the problem. Easy I hope. I'll probably do this in two weeks, parts won't get here until June 3 or 4. To Gnar doggy: no sqeaking in reverse. Thank you for your input! I will post results.
  9. Jun 9, 2024 at 1:29 PM
    Zebra1963
    Zebra
    It must have been my imagination that the vibration had gone away. It only got worse over the following week. So I finally found some time to drop the drive shaft yesterday. I replaced the front and center u-joints as well as the carrier bearing. Front u-joint was pretty much shot, but both the center and rear diff u-joints seemed totally solid. Since I had to get to the carrier bearing, I went ahead and replaced center one since it was half taken apart. Left the rear one alone, it's good for now. Got it all back together, and now ZERO vibration. I saved $$$ doing it myself. The u-joints and carrier bearing were $75 and the OMT Ball Joint Press and U-Joint Removal Kit was $44, and I'm sure I'll use it again. Also super helpful was perhaps the best Taco DIY YouTuber ever. Followed most of his instructions:
    https://www.youtube.com/watch?v=6WvlVa7OzS8
