Slight wandering, alignment numbers
Discussion in '1st Gen. Tacomas (1995-2004)' started by NegroTundra, Aug 28, 2011.
  1. Aug 28, 2011 at 5:22 PM
    NegroTundra
    NegroTundra [OP] Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    So I have had a bit of wandering every since I've owned the truck with my OME lift, not a big deal but can get annoying at >70mph with any hint of a cross wind. Went to the shop today and told them of my woes, here's the numbers:
    BEFORE:
    FL FR
    Camber -0.3 0.2
    Caster 1.0 1.1
    Toe -0.16 0.22
    AFTER:
    FL FR
    Camber 0.0 0.1
    Caster 0.5 0.5
    Toe 0.04 0.03
    Thoughts? My understanding is postive caster is the most important thing, looks like they didnt listen to my concern. Havent driven the truck high speed since so I cant really comment on handling post-alignment.
  2. Aug 29, 2011 at 1:29 PM
    NegroTundra
    Land of Enchantment
  3. Aug 29, 2011 at 3:06 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    The OME's height limit the amount of caster they can dial in. No one will be able to do any better with the caster. This is true of any lift. I don't have my numbers handy, but this is a common issue. So at higher speeds, it can feel a little twitchy.
    The solution is adjustable UCAs, like the Light Racing UCAs. By default, they provide 2 degrees of additional caster out of the box, and they offer additional adjustability. I am getting tired of the amoutn of concentration needed on long drives. LR UCAs are next on my list, but it won't happen until this winter.
  4. Aug 29, 2011 at 7:09 PM
    NegroTundra
    Land of Enchantment
    Thanks scocar. Hmmmm, guess I'll put those on my list as well; although I swore I'd never screw with aftermarket uca's again after my bad experience with uniball camburgs on my 03 Tundra. Made the whole truck feel dangerous to drive on the interstate at >75mph. However the reason for that is still up for debate. LR uca's are not uniball correct?
  5. Aug 29, 2011 at 7:42 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Correct. The balljoint is mounted in the UCA, thought, instead of the spindle. This allows it to be adjustable.
    http://www.spc-tv.com/install/lt-suv/65-25460-toyota-tacoma-upper-control-arms.html
  6. Aug 30, 2011 at 12:51 PM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    Sorry to jack your thread, but I am getting ready to install these on my 04 D-cab. Do you recommend just setting them at their "0" setting? I am adding toytec coilovers at the same time.
  7. Aug 30, 2011 at 12:54 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    I've not looked at the first gen, but they should come with instructions on how to set them up... The "zero" position on the 2nd gens adds 2 degrees of caster. That seems to be just about the right amount.
    Just check your instructions and set them at +2 degrees.
  8. Aug 31, 2011 at 10:59 AM
    brs127s
    O'Fallon, MO
    The plan is to set them at the 0 shim setting. Starting on it tonight.
  9. Jun 12, 2012 at 11:22 AM
    NegroTundra
    Land of Enchantment
    Bumpin this old thread....
    For those of you who have installed these...whats the verdict? Good alignment numbers? Good tire wear? My lift has now started my tires to cup, even though I rotate every 7k. Gonna have to do these soon but wondering what you guys have to say,.
  10. Jun 12, 2012 at 12:32 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The Light Racing UCAs are nice because they fix the low caster issue that happens when lifting the suspension. And since the use a High Angle Ball-Joint, there are no loud obnoxious squeaks to deal with.
    http://www.wheelersoffroad.com/9504sptacoarms.htm
  11. Jun 12, 2012 at 12:48 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Caster won't help cupping. Cupping is a result of worn components. Maybe you have a bad ball joint or wheel bearing? Tires balanced properly?
  12. Jun 12, 2012 at 2:34 PM
    NegroTundra
    Land of Enchantment
    Thanks YotaDan....
    I have new lower balljoints and assume my wheel bearings are good....i don't hear any "wheel bearings are going bad" noise. No vibration so I think tires are balanced too. i may need to check upper balljoints
  13. Jun 12, 2012 at 6:28 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    hey, guess what.
    Last time I took it in, I told them specifically to crank the caster as much as they could (with stock UCAs).
    Guess what? It worked a lot better. Better tracking, less twitchy.
    I think unless you specify this, they just do a toe & go.
    I had to have him tweak it once more because it was heading to the gutter a bit, but after that, it's great.
    Dont' have numbers handy, but YOU DON'T NEED THE UCAs with this small amount of lift.
    Worth a try before you buy UCAs, and of course resolve other issues you may be having (cupping etc.)
  14. Jun 12, 2012 at 8:05 PM
    NegroTundra
    Land of Enchantment
    Good to hear scocar.....though I tried that trick and it would still act quite twitchy, though the caster was still in the red numbers. (Maybe this is what I get for purchasing lifetime alignments at Firestone...I think they're sick of me). Would really like to know what they got yours to with stock UCA's. I think I will go ahead and just replace my upper ball joints and start there. 97k on the truck now and never been replaced, worth a shot. Then I plan to ramrod those damn kids working at Firestone and emphasize the caster number. Though last time they told me they would never be able to get it right because I "had more lift on the drivers side then the passenger side". They were going off the fact that I had a drivers side 1/4" spacer in to compensate for the Taco Lean. I told them...pull a tape on it, I guarantee the drivers side is lower than the passenger. They never would satisfy my request because they knew I was right. Anyways, will update on the cupping at least, once I get new upper BJ's in.
    Cheers
  15. Jul 15, 2012 at 12:07 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    After my recent OME lift (881/10mm spacer/90004) I'v been experiencing a few issues with wandering, pulling when braking, and the tow was waay out, so I went to Firestone today to get an alignment. I emphasized the highest caster they could get, but I'm a bit confused with the results.
    Here are the #s
    Before:
    FL / FR
    Camber 0.2 / 0.7
    Caster -0.2 / 0.0
    Toe 0.53 / 0.57
    After:
    Camber -0.3 / 0.0
    Caster -0.3 / -0.6
    Toe 0.03 / 0.09
    Can anyone help explain why the Caster has now gone down :confused: Any other insight on these numbers is greatly appreciated???
    Also, the tech left a note that the "inside and outside cams are not even with eachother" is this a problem?
    Thanks!
  16. Jul 15, 2012 at 12:31 PM
    rushr
    rushr Well-Known Member
    04 DC TRD 4X4
    OME 883 Coils, Dakar Leaf Packs/D6XL AAL, Nitrocharger Sport Shocks, ARB Bumper, Warn M8000 w/Synthetic Line, BAMF Sliders, Odyssey Battery, ProComp 7069 15x8, BFG KM2 33x10.5x15, Frame End Cap Mod, Hayden Transmission Cooler
    Your caster changed because they changed your camber. As you dial in one it affects the other. You may need aftermarket UCAs to get what you want.
    You need to look at brake issues if it pulls when braking
  17. Jul 15, 2012 at 4:03 PM
    NegroTundra
    Land of Enchantment
    +1.........I broke down and purchased Light Racing UCA's last Friday.....hoping my truck drives like it did when it was stock.
  18. Jul 16, 2012 at 5:53 AM
    TIPICOTACO
    Tyler
    nw nj
    UGh, well I guess I knew thats the way to go... Keep us posted how they work for ya :)
  19. Jul 16, 2012 at 2:47 PM
    NegroTundra
    Land of Enchantment
  20. Jul 23, 2012 at 9:44 AM
    NegroTundra
    Land of Enchantment
    Well I am happy to report that the Light Racing Adjustable UCA's solved all my issues. The truck handles like a dream on the highway now, with little to no "twitchy" action and takes much less effort to go for a highway cruise. The install was a bit of a bitch...those stock upper BJ's are stubborn, and the whole job took me about 9 hours! I had to get all angles of creative to get them out with my limited tools, however relentless pursuit payed off.
    All was worth it in the end. My alignment numbers are now in the green. I took it on some rough rocky trails this past weekend, and I feel the truck handles the bumps better too, maybe because of the newly designed SpecRide poly bushings. However, i now have a clicking coming from the passenger side, but I think it maybe the swaybar end links. Nothing really great in the photos, as these UCA's definitely don't have as much bling factor as the Camburg and TC UCA's, but worth showing anyway. They are definitely more heavy duty than the stock UCA's.
    BTW...the best price I could find for these was FatBobsGarage....just under $390 shipped, and they got here fast!
