slight whine at low revs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KRich, Apr 12, 2012.
  1. Apr 12, 2012 at 4:44 AM
    KRich
    KRich [OP] Well-Known Member
    BC, Canada
    07 Black DCSB TRD Sport 4x4
    Hi all,
    Am looking for some input on a noise I can hear when I am starting to move from a stop and at low speed. To me it sounds identical to when the power steering fluid is starting to get low but I topped it up and the sound is still there. My Taco has 85000 kms on it but I shouldn't have to replace any belts or anything yet should I? Thanks for any help.
  2. Apr 12, 2012 at 4:55 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    The sound is coming from the front...middle...or rear of the truck?
  3. Apr 12, 2012 at 10:46 AM
    KRich
    BC, Canada
    Looks to be coming from the front, it is relatively subtle but now my truck sounds more like a Ford :D
  4. Apr 12, 2012 at 10:58 AM
    09tacorunner
    09tacorunner Well-Known Member
    Duke City
    09 PreRunner TRD OffRoad
    it could be the alternator. my moms car had the same whine and it turned out to be the alternator.
  5. Apr 12, 2012 at 11:02 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    You mean a supercharger? :p
  6. Apr 12, 2012 at 11:15 AM
    Warputer
    2011 TRD Off Road
    Does the sound get louder as you turn the steering wheel.....especially when the truck is not moving (more strain on the pump when it's parked)? The pump for the power steering can be bad even if it's full.
  7. Apr 12, 2012 at 11:35 AM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    I have that same noise. When I turn the wheel, it makes no difference. I'm thinking the alternator is a good bet.
  8. Apr 12, 2012 at 4:03 PM
    Warputer
    2011 TRD Off Road
    Well? Update KRich?
  9. Apr 12, 2012 at 4:05 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    One of the pulley bearings most likely. Its a common problem with the truck. Easy fix!
  10. Apr 12, 2012 at 6:51 PM
    KRich
    BC, Canada
    Thanks for the input guys! I did realize today that it is present all the time even when not in gear and does get more pronounced as I rev up the engine (only to a certain subtle level as the general engine noise overpowers it fairly quickly).
    I do have an amp and modest stereo installed but I was fairly sure that my TRD Sport had the upgraded alternator so I hope that wouldn't be going yet. Happy to hear that it is an easy fix if it's a pulley bearing.
    Anyhow I probably won't get a firm diagnosis or repair in the near future as I just got brand new 285/70/17 BFG A/T's installed today and have to let my bank account cool down for a bit :D
  11. Apr 12, 2012 at 7:05 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Pull the belt off and spin every pulley by hand, if any of them make noise, replace. Or leave and at least you know what is wrong.
    Takes like 15 minutes.
  12. Apr 12, 2012 at 7:08 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Most likely this....
    Did my idlers last year. Rock Auto had the best price.
  13. Apr 12, 2012 at 7:12 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Oh and if it is an pulley bearing going south, you'll know. It'll get louder as it gets worse until you think you do have a supercharger. It was actually kinda fun for the couple days mine got really loud.
  14. Apr 20, 2012 at 11:30 PM
    KRich
    BC, Canada
    Was just wondering what a reasonable charge would be for the dealership to fix one of the pulleys? I know I should learn how to do it myself but I have a young child at home and time is not easily available.
  15. May 2, 2012 at 5:41 PM
    KRich
    BC, Canada
    bump
    Anyone had to get this fixed at the dealership?
  16. May 2, 2012 at 6:18 PM
    Bruce87
    Bruce87 Member
    Canada
    2006 trd sport
    I just had two fixed 2 days ago 280 dollars total one was 89 the other was 97 plus labor lucky mine was under warranty Much cheaper online.
  17. May 3, 2012 at 11:45 AM
    KRich
    BC, Canada
    Thanks for the heads up, just wanted to know the ballpark so the dealership wouldn't try to bend me over too much!
  18. May 3, 2012 at 11:47 AM
    KRich
    BC, Canada
    Just noticed you have an 06 and you managed to get it done under warranty?
  19. May 3, 2012 at 1:54 PM
    Bruce87
    Bruce87 Member
    Canada
    2006 trd sport
    Yea my truck came with extended warranty From previous Owner total bill was 920 bucks with a new lower steering shaft crazy dealer prices
