Slightly Noisy Differential??
Discussion in '1st Gen. Tacomas (1995-2004)' started by bayoukid, Nov 15, 2013.
  1. Nov 15, 2013 at 8:02 PM
    bayoukid
    bayoukid [OP] Active Member
    Gene
    Summerfield N.C.
    2000 Prerunner TRD 2wd 6 cyl 4x2
    Tow Hitch, tranny cooler
    I have a 2000 Tacoma Prerunner TRD 2WD.
    it has 103000 + - miles on it, it has the possi track rear end option.
    It never has been off road and has pulled only a Pop-up tent trailer.
    The Situation:
    I noticed about 3 weeks ago a noise emitting from the underbelly of the truck, at first it was really slight. Then as time ticked on and I paid more attention to it, it became slightly more audible. Now when I drive down a surface street with the cement divider ( K-Rail) I hear a very slight high pitched squeal / and jingling sound. I looked under the truck and even checked all of the components, even the muffler which i know can have particles dislodge inside and rattle. I couldn't find it.
    I brought it to my mechanic and he put it on the rack and put in drive. He said the noise is coming from the differential. He however said in order to decipher what is causing the noise he would have to tear it apart.
    The Question:
    Is there anybody out there that has experienced this situation?
    I am about to start pulling a 3800 lb TT. and I live in Southern Cali where there are lots of hills. Kind of worried.....
    Any help would be great.
  2. Nov 15, 2013 at 9:18 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Is it a posi or a locker?
  3. Nov 15, 2013 at 9:59 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Noisy diff is not what you want to hear. Could be a problem that will leave you stranded.
    AFAIK, Tacos did not have a 'posi' available from the Factory, just the e-locker on most of the TRD models. Is there a 'servo' on the side of the diff?
  4. Nov 15, 2013 at 10:03 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Is it making a whining sound?
  5. Nov 15, 2013 at 10:32 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When was the last time you changed your diff gear oil? And/or lubricated your drive shaft ujoints?
  6. Nov 16, 2013 at 12:48 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    if it's squealing it's a dry shaft. lube your shaft and see what happens.
    your driveshaft that is.
  7. Nov 16, 2013 at 6:59 AM
    bayoukid
    Gene
    Summerfield N.C.
    Servo, yea I think thats what that box ,lookin thing is, poking out of the front of the diff. It has wires leading to it.
  8. Nov 16, 2013 at 7:00 AM
    bayoukid
    Gene
    Summerfield N.C.
    Never changed diff oil, lub u-joints every other oil change
  9. Nov 16, 2013 at 7:08 AM
    bayoukid
    Gene
    Summerfield N.C.
    Wouldn't say a whining sound it's actually more of a jingle like something is loose under there however I can't locate it and it is only heard when I am up against a wall of some sort. like a k-rail.:confused:
  10. Nov 16, 2013 at 7:10 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Need to get the fluid changed ASAP
  11. Nov 16, 2013 at 7:19 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Dude. Change the diff oil or else [​IMG]
  12. Nov 16, 2013 at 7:50 AM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    My rear diff started grumbling, grinding, and groaning a little too loudly after 175,000 miles and I also felt it got a little too hot. Yes, I changed the rear diff oil regularly. I bought a new third member at 185,000 because I was driving across the country and didn't need any worries. The last thing I wanted was it to "explode" internally. Sold the old one for $250 though. Mines a 2000 with e-locker.
