Slightly Over 40 and 50s Thread. Please Refrain From My Lawn, I’m Having A Midlife Crisis
Discussion in 'Off-Topic Discussion' started by shane100700, Mar 28, 2020.
Thread Status:
Not open for further replies.
  1. Mar 28, 2020 at 7:35 PM
    #101
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Someone has been deleting posts again.
  2. Mar 28, 2020 at 7:37 PM
    #102
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    OH OK! I thought I noticed it the other day too but maybe I was wrong. No big deal. Not like I win a prize.
    wilcam47 and shane100700[OP] like this.
  3. Mar 28, 2020 at 7:39 PM
    #103
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    There is that. I also put rim guard in the tires, so that added another 700 lbs. sometimes I wish we had purchased a bigger tractor, but just can’t justify anything more than the L2501.
    I was building a road off my driveway today, and had an epiphany that 1.5” wheel spacers would be nice on my rather steep property.
  4. Mar 28, 2020 at 7:41 PM
    #104
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The point I need to make clear, is often we do a controlled burn, but the " nosy Nancy a 1/2 mile away smells smoke.
    The FD gets called out because the 911 call came in. They have to roll. False alarms still cost money and sleep for the pros.
    No response required. I'm done soap boxing. I want to go back to goofing off.
  5. Mar 28, 2020 at 7:42 PM
    #105
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Air Force... :rolleyes:
  6. Mar 28, 2020 at 7:42 PM
    #106
    shane100700
    shane100700 [OP] Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    My neighbor is in the FD, I don’t burn, but I could.
    CXYyuppie and koditten[QUOTED] like this.
  7. Mar 28, 2020 at 7:43 PM
    #107
    Deathdealer
    Deathdealer Well-Known Member
    Ricky Spanish
    Texas
    Could y’all keep it down in here please?
    You punks been revving up those tractors all night!
  8. Mar 28, 2020 at 7:45 PM
    #108
    ColoradoTJ
    Colorado
    I just passed 80 hours today. We mostly use it for snow removal. Let me rephrase that. I use it for snow removal.
    I wasn’t aware I could add a mower deck to an L series Kubota tractor.
    shane100700[OP] and CXYyuppie like this.
  9. Mar 28, 2020 at 7:46 PM
    #109
    CaptAmerica
    Cap
    You’re in Houston - how can you hear that over the random gunfire and single-car accidents?
  10. Mar 28, 2020 at 7:47 PM
    #110
    CXYyuppie
    Craig
    SE.LA
    In the last 10 days off I have busted my ass trying to get everything outside finished, cleaned, or put away. I’m actually ahead of my work plan. I’m not sure what I’m going to do tomorrow, but hopefully I can relax a little.
  11. Mar 28, 2020 at 7:47 PM
    #111
    CaptAmerica
    Cap
    Then I need to look at dad’s again - I thought it was a 525.
  12. Mar 28, 2020 at 7:47 PM
    #112
    rmepilot
    Rob
    Huntsville, AL
    Happened to me too. :tinfoilhat:
    CXYyuppie and shane100700[OP] like this.
  13. Mar 28, 2020 at 7:51 PM
    #113
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    24hp of 3cyl diesel fury ! 1100cc of awesome ! Eat my dust !
    koditten and CaptAmerica like this.
  14. Mar 28, 2020 at 7:53 PM
    #114
    koditten
    Kirk
    Central Michigan
    The torque! What's the torque!
  15. Mar 28, 2020 at 7:55 PM
    #115
    Blkvoodoo
    Kevin
    Near Clayton NC
    my junk is 23years old, 1441hrs as of today, another 30hrs and I'll have put 500 on myself may take a year or so....
  16. Mar 28, 2020 at 7:55 PM
    #116
    Blkvoodoo
    Kevin
    Near Clayton NC
    It’s got some.....some where..... (50ftlb)
  17. Mar 28, 2020 at 7:55 PM
    #117
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I thought them big 10 gallon hats helped block sounds? :notsure:
    rmepilot and Deathdealer like this.
  18. Mar 28, 2020 at 7:56 PM
    #118
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    There's a message counter? is that like an Odometer?
  19. Mar 28, 2020 at 7:58 PM
    #119
    ColoradoTJ
    Colorado
    He probably has a B series tractor.
    I almost purchased a B3350 instead of the L series.
  20. Mar 28, 2020 at 7:59 PM
    #120
    Taco-Grinder
    Dan
    Fond du Lac, WI
    We did a control burn a few years ago. Burned off 2 acres. We had the fire fighting class from local tech school do it. Nice thing about having them do it was they accepted all responsibility if it got out of control.
Thread Status:
