Slightly over tightened new valve cover gaskets
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, Nov 30, 2012.
  1. Nov 30, 2012 at 4:10 AM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    NorCal
    2001 TRD 4x4 Xtra Cab
    Tires- 31x15x10.5 Cooper Discovery AT3
    I put brand new valve cover gaskets and new spark plug tube gaskets on my truck 2 weeks ago and I slightly over tightened them and am wondering if after 2 weeks I can loosen them to their correct torque or if I should leave them be. I haven't really driven it because I haven't been home for those 2 weeks so I that is why it took me 2 weeks really worry about it. Any suggestions would be fine. I probably tightened them to around 70-80inlbs instead of the 53 that is recommended.
  2. Nov 30, 2012 at 5:41 AM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Personally I would loosen them, retorque in a pattern, and drive it. I've rebuilt a lot of small engines that I didn't even torque the heads/gaskets, and even though they don't create as much compression, they have all been fine for the long term.
  3. Nov 30, 2012 at 12:20 PM
    Bamahoyt
    Ted
    NorCal
    Thanks for the input
  4. Dec 1, 2012 at 6:09 AM
    Bamahoyt
    Ted
    NorCal
    Any other thoughts?
  5. Dec 5, 2012 at 6:37 PM
    Bamahoyt
    Ted
    NorCal
  6. Dec 5, 2012 at 7:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Depending on your definition of "slightly"... Leave it.
    If they aren't leaking, you didn't deform the cover (more likely on a stamped steel cover/pan).
    If you're talking you went to 25 inch pounds instead of 20, it's not a big deal.
    If you went "a lot" over, then the fastener may be stretched... remove, replace the gasket, and reassemble with new fasteners.
