Slightly rough shifting in and out of first gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by slymedusa, Feb 16, 2024.
  1. Feb 16, 2024 at 9:25 PM
    slymedusa
    slymedusa [OP] Complete Newbie
    Jorge
    Miami, FL
    2002 Silver Tacoma Prerunner
    Hey everyone, getting some odd behavior from my A/T lately. It’s starting to shift a bit rough into and out of first gear. Coming to a stop feels a bit like axle wrap. This happens no matter the engine temperature, but I can kinda mitigate it by really babying it like coming to a very gentle stop or slowly releasing brakes and accelerating gently. I checked the transmission fluid while the engine was hot and it looks like it’s overfilled.
    Part of my plan to address it is to replace the fluid and filter as I just bought the truck a couple months ago. However based on my research overfilled fluid doesn’t typically cause this symptom. Any thoughts?
  2. Feb 16, 2024 at 9:47 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    How long u owned the Taco?
    Miles?
  3. Feb 17, 2024 at 12:42 AM
    slymedusa
    Jorge
    Miami, FL
    Since December (two months and some change), 234k miles
  4. Feb 17, 2024 at 9:19 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Which rear springs are on it? What you described sounds like axle wrap. Old clapped out springs.
    Why do you think it is the trans?
    slymedusa[OP] likes this.
  5. Feb 17, 2024 at 10:15 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Axle wrap or really bad u-joint(s). I had a clunk when shifting from park to drive and back, turned out to be the very back u-joint. Still have axle wrap and that’s usually most noticeable when I take my foot off the brake.
  6. Feb 17, 2024 at 10:41 AM
    slymedusa
    Jorge
    Miami, FL
    Most likely stock from the dealer. I just changed the shocks (well the shop did…) but didn’t think to change the springs at the same time.
    I think it’s the transmission because I don’t know any better lol I’m very new to doing automotive work which is like 80% of the reason why I’m here
  7. Feb 17, 2024 at 10:42 AM
    slymedusa
    Jorge
    Miami, FL
    Kinda sorta sounds like my symptoms. Any diagnostic tests I can do to figure out if it’s that?
  8. Feb 17, 2024 at 10:58 AM
    Kevins60
    Kevin
    Odessa FL
    Grease all the u-joints and see if the symptoms change. Unfortunately you can’t really test u-joints on the truck, you’ll have to drop the driveshaft and rotate each u-joint through it full range of motion. If you hear anything or feel a change in resistance as you move the u-joint it’s bad. At 22 years and 230k miles you’re pretty much guaranteed the rear leafs are shot.
  9. Feb 17, 2024 at 11:09 AM
    slymedusa
    Jorge
    Miami, FL
    I’ll add it to the list… appreciate it!
