Slightly Wider Tires (245 v. 265)
Discussion in '4 Cylinder' started by godsend, Aug 23, 2015.
  1. Aug 23, 2015 at 5:52 PM
    godsend
    godsend [OP] Well-Known Member
    Norcal
    14 Access Cab 4x4 Base
    Flux Capacitor 1.21 Gigawatt
    It's about time for me to get new tires to replace the stock AT20s. I've decided on the BfGoodrich KO for increased off-road performance, but I don't know if I should go with the stock width of 245 or the slightly wider width of 265. This Tacoma is my daily driver, so would an extra 20mm measurably change fuel consumption/acceleration? I may be too concerned, but I'm not sure if the 2TR/trans is that easily affected. Thanks in advance
  2. Aug 23, 2015 at 8:25 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I believe many folks on this forum have done that. I have 265s (load range E) on mine. The speedometer and odometer are just about right on with them. The only thing I noticed is that I run it a bit faster before shifting. I stay out of 5th (manual transmission) below about 45 mph.
  3. Aug 23, 2015 at 8:29 PM
    Nacho Daddy's Taco
    Nacho Daddy's Taco Well-Known Member
    Austin, TX
    2017 Tacoma SR Double Cab Prerunner 4CYL Auto MGM
    2017 4Runner Trail Wheels Billstein 5100s @ 1.1 w/ 1.5" rear block 265/70/17 Cooper HTP
    KOs are significantly heavier than the dunlops even in same size as they are heavier duty LT tires. You can view the specs including weight at tirerack.com. If you are concerned about MPG you may want to reconsider the BFG KO tires.
  4. Aug 23, 2015 at 8:34 PM
    azreb
    azreb Geezer
    TN
    I understand the concern about MPGs and heavier tires. However, my experience has been that driving habits have more effect on gas mileage than that weight. As I mentioned, I have load range E tires on mine and get much better gas mileage than most of the folks here report for their 4 bangers.
    ZachPrerunner likes this.
  5. Aug 23, 2015 at 8:35 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I haven't noted a drastic change in MPG's from my Firestone Destination LE to BFGoodrich KO's. I did however went from 265 to 245. The MPG's average anywhere from 17-18 city to 20-21 highway. The speedometer wasn't affected either. If you get a bigger KO, that will effect MPG's severely, but 265's shouldn't affect it that much.
    EDIT: Spelling
  6. Aug 23, 2015 at 8:39 PM
    ZachPrerunner
    Southeast TN
    If people are so concerned over gas mileage, they shouldn't have bought a truck IMHO. I understand if you want to maintain optimal mileage for long travel times, but that's about it. Trucks just outright suck in MPG's.
  7. Aug 24, 2015 at 1:47 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    If you go the 245 route I would love some pictures,
    I too am ready to change out the stock Dunlops but also considering price as some online tire dealers have the 265 BF Gs cheaper than the 245s.
    I would love a reason to get a leveling kit and all, :devil:
  8. Aug 24, 2015 at 10:25 AM
    ZachPrerunner
    Southeast TN
    Here's mine with 245s. The first image is stock suspension. The front view is with the Billies set @ .85 with sport coils.
  9. Aug 24, 2015 at 11:42 AM
    Greenbean
    Zack
    Western NC
    Look great,
    Why did you stay 245? Just curious...
  10. Aug 24, 2015 at 11:44 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I went from P245/75 Dunlop to 265 Hankook Dynapro and Cooper ATP P265/75, weight difference is approx. 10 lbs per tire and 1.2" in height, MPG went from 23/24 average to 18/19 average with 2.7 and auto trans.
  11. Aug 24, 2015 at 2:06 PM
    ZachPrerunner
    Southeast TN
    I actually went from 265's down to 245's. To be honest, I have not a clue as to why I went back to the stock size lol. I'm thinking about upgrading to some 33's.
  12. Aug 24, 2015 at 4:09 PM
    Greenbean
    Zack
    Western NC
    Lol...
    How many miles on your BFGs?
    They 10 ply, I may be a buyer if you need to sell them...
  13. Aug 24, 2015 at 4:18 PM
    ZachPrerunner
    Southeast TN
    I currently have around 6,000 miles on em. I'll let you know if I decide to sell!
  14. Aug 24, 2015 at 5:42 PM
    Greenbean
    Zack
    Western NC
    Please do, thanks.
    I'm in Asheville so it probably wouldn't be difficult to meet up and swap tires for cash.
  15. Aug 24, 2015 at 5:49 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Im.going from my stock 265 to 255 soon.
  16. Aug 25, 2015 at 1:50 AM
    Greenbean
    Zack
    Western NC
    :cheers:
    One day I will see a, lift, re-gear and 255/85/R16s...
  17. Aug 25, 2015 at 5:43 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    I have had 265/75/16's on mine (all stock) for almost 9 months with zero issues.
    These are BFG RTerrains's, 10ply LT's.
    Gas mileage is only slightly worse, and i didn't even notice road noise like i thought
    i would. A much better look and feel compared to the 245's AT-20's.
  18. Aug 25, 2015 at 6:12 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Diameter and weight of a tire will affect your mileage more than width. Which 265 size are you referring to? 265/70/16 is the same diameter as your 245/75/26 but slightly wider. This size comes stock on TRD OR models. 265/75/16 is one inch taller than your current tires. If your concern is mainly mpgs, stick with the stock size. Also, going with a P rated tire versus LT will save you some weight, and therefore help your mileage.
    For reference- I was averaging 20mpg on stock P245/75/16 tires and factory suspension. After new suspension and installing LT265/75/16C tires, I am now averaging 17.5. Some of that loss probably came from the change in aerodynamics cause by lifting the truck, but I have no way of knowing how much.
    bjmoose likes this.
  19. Aug 25, 2015 at 6:26 AM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
  20. Aug 25, 2015 at 6:30 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    I have 265s, average 18/20
