Slip indicator, ABS and blind spot lights after ECGS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rab89, Nov 27, 2019.
  1. Nov 27, 2019 at 4:36 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    EDIT:
    I was shocked to hear that it was all from the abs/speed sensor wire.
    I didn't drop the hub or anything, these must be extremely fragile. none the less it's fixed!
    I seem to have F*cked up!
    I did the ECGS bearing on my 2017 Tacoma the other day and now I have lights on and problem.
    I have tried the VSC calibration, but I can't seem to be able to get it to work properly. I'm not getting the correct flashing lights but I am certain I'm doing it right.
    The slip indicator, ABS and blind spot monitor lights are all on and giving me error messages.
    I also get an error message when I try to shift into 4wd.
    I checked the ABS fuses and they seem fine.
    Before going to the dealer, anything I should try?
  2. Nov 27, 2019 at 4:40 PM
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    ABS sensor wire broke on that drivers hub when you moved it around?
    Superdave1.0, rab89[OP] and JC15Taco like this.
  3. Nov 27, 2019 at 4:45 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Blind-spot monitor on a '12?
  4. Nov 27, 2019 at 4:53 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    The post says 2017, you didn't actually read the post did you?
    rab89[OP] likes this.
  5. Nov 27, 2019 at 4:56 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Oops...just looked at his Sig. :anonymous:
    rab89[OP] and GreyBaldTaco like this.
  6. Nov 27, 2019 at 5:01 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I had a quick look and it seems to be plugged in at the hub and the wire in one piece, but I'll look closer!
    Edit:
    I wire all looks good, but is there anything on the backside of the connector I could have broken?
  7. Nov 27, 2019 at 5:21 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    does replacing the ECGS void the toyota warranty ?
  8. Nov 27, 2019 at 6:37 PM
    snowtaco2
    snowtaco2 Well-Known Member
    Nobody
    Middle Of USA
    2018 OR BBP
    Stock for now
    Is it possible that the wires inside of the outer shielding could have broken? Did you stress the wires at any point during the install?
  9. Nov 27, 2019 at 6:48 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I guess my answer there is anything is possible, but I didn't drop the hub/brake part at all...
    I left it hanging on by the UCA, twisted it out of the way toward the back of the truck and secured it while I worked.
  10. Nov 27, 2019 at 6:57 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    They’ll never know. I’ve read about some owners getting the ECGS bushing installed at the dealer. Don’t know how that’s possible, but some have done it.
  11. Nov 27, 2019 at 11:43 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
  12. Nov 28, 2019 at 12:33 AM
    edgarcg2
    edgarcg2 Well-Known Member
    Edgar
    2018 cement Tacoma dcsb off road 4x4
    Did you get it aligned after?
