Slip Indicator Light and ABS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stealntime, May 26, 2024.
  1. May 26, 2024 at 10:28 PM
    Stealntime
    Stealntime [OP] New Member
    Hello,
    I have a 2020 SR 4wd Tacoma. I had a local auto shop replace a rack and pinion. The shop also broke my clock spring and steering angle sensor when doing this. They replaced both.
    Now when driving highway speeds and making slight turns my slip indicator light is flashing. Less often it is happening when driving straight and causing my brakes to not work, ABS braking causes it not to stop. Went through a couple stop signs because I couldn't stop. A few times it has thrown a code that there was no connection to steering angle sensor. I assume he put a cheap aftermarket one in. Would buying OEM help this? Wheel speed sensors are all reading the same speed and steering angle senor is reading 0 when straight.
  2. May 26, 2024 at 10:41 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’d take it back and tell them to fix it right.
    Why did it need a steering rack in the first place?
    Robnik likes this.
  3. May 26, 2024 at 10:47 PM
    Stealntime
    I am not taking it back to them. He is clueless on it. He had the truck for over 2 months trying to figure it out and replaced the clock spring and SAS twice as he did more damage each time he worked on it. He didn't charge me.
    Rack and pinion due to a leak.
    Robnik and Chew like this.
  4. May 26, 2024 at 11:14 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Gotcha, I think there’s what is called a “zero point” calibration, try a search,,, sorry I’m on my phone.
    GL
    Robnik likes this.
  5. May 26, 2024 at 11:18 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Go to a real mechanic, not some stupid "technician". He doesn't know what he's doing. He'll only make it worse.
  6. May 27, 2024 at 7:59 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Yes! Non-OEM steering angle sensors are still not up to standards and we've seen this issue a few times here with replacements.
