Slip indicator light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cam@1, Mar 28, 2025.
  1. Mar 28, 2025 at 9:12 AM
    Cam@1
    Cam@1 [OP] New Member
    2009 taco with codes c0278, c1201, c1241. No ABS light on but my slip indicator light is on. Brakes work fine. I replaced ABS fuses and slip indicator light went out for a couple days and then came back on. Any help would be appreciated.
  2. Mar 28, 2025 at 9:13 AM
    545 Well-Known Member
    2015 Access Cab
    What kind of code reader are you using? Usually need an advanced one to see wheel speed sensor issues
  3. Mar 28, 2025 at 9:46 AM
    Cam@1
    I went to auto zone and they pulled the codes. Thanks for the reply. Not a mechanic but would like to try and figure it out.
  4. Mar 28, 2025 at 10:05 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Reset the VSC
  5. Mar 28, 2025 at 10:11 AM
    Cam@1
    How do you reset the VSC? Thanks for your time.
  6. Mar 28, 2025 at 10:15 AM
    zguy1
    zguy1 Well-Known Member
    Midwest
    You can clear the codes using a code reader. This assumes you are using one that can connect to and read the ABS module.
  7. Mar 28, 2025 at 10:56 AM
    Cam@1
    Thank you.
